03-13-2019, 08:59 PM | #1 |
Rep 271
US M340i Configurator Images
Featured on BIMMERPOST.com Hi all, Call me obsessive but I figured out how to reverse engineer the M340i configurator images from the following page. https://www.bmwusa.com/vehicles/3-se.../overview.html. My M340i is waiting at port so something to do in the meantime When you click on the "performance" tab to get to the M340i, it uses javascript to load in the following image: https://cache.bmwusa.com/cosy.arox?p...ARENT&angle=40 You can modify the query parameters in this URL using the M340i order guide to configure the car that you like: Vehicle (ex. 203Q): model number from order guide. 203Q is the model number for the M340xi. Paint (ex. P0C31): paint option code from the order guide, prepended with "P0". Change the last 3 characters to the paint code you want. C31 is the code for Portimao blue so I changed it to "P0C31" sa (ex. S01PD): A comma delimited list of all option codes, each prepended with "S0". Notice the "S01PD" option, which is the 18 inch wheels option code 1PD. 1PL is the code for one of the 19 inch wheel options. Change this value to S01PL and you get the 19 inch wheels. Another example: add S05AZ, which is laser lights (5AZ) and see that the headlight style changes. I'm not sure how it behaves when options conflict, so I just removed all options except for the two I listed here (https://cache.bmwusa.com/cosy.arox?p...ARENT&angle=45 I haven't experimented too much further options wise. quality, width, sharpness: Not sure what the maxes are here, but setting them each to 9999 results in a larger, higher quality image. angle (ex. 40) Angle view of configurator photo. Can specify value from 0 to 360. Anyway, enjoy Last edited by RPM1123; 03-20-2019 at 09:50 PM.. |
12
03-13-2019, 09:56 PM | #2 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
Nice!
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
03-14-2019, 05:34 AM | #4 |
Rep 10
Nice work!
Check out this page: https://www.bmw.de/de/neufahrzeuge/3...entdecken.html There is something like a "mini configurator" in the bottom part of the page where you can toggle through the lines (sport, m-sport, ...) and where also the m340i is included. You can then select colors, wheels, ... |
03-14-2019, 01:25 PM | #6 | |
Rep 1,205
11’ E92 ///M3
15’ F82 ///M4 18’ G30 540i ///Msport 21’ G20 ///M340i 24' i20 iX xDrive50 |
03-14-2019, 01:51 PM | #7 |
Rep 3,074
Drives: G06/G20/F30/F15/F10/E90
Can you reverse engineer the G80 M3
03-14-2019, 01:57 PM | #8 |
Rep 455
They just need to put the configurator online. You can order one so silly that you can't use configurator.
Same with X3/4M ... get the config online
Current: 2022 ///M3 San Marino Blue, Comp, xDrive, Fjord Blue/Black --plus-- 2022 ///M440i Gran Coupe, Aventurin Red, Cognac Vernasca
Past '20 X4 ///M Competition Toronto Red -- '16 ///M3 Tanzanite Blue, ZCP -- '15 ///M3 Mineral Grey |
03-14-2019, 02:46 PM | #9 |
Rep 2,499
Looks like they took the images down.
03-14-2019, 03:37 PM | #10 |
Rep 65
The configurator for the M340i on the Canadian website is now live.
All colors and configurations seem to be working as well. https://www.bmw.ca/en/ssl/configurat.../config/PAINT/ My favorite new feature is the night mode with rotation.
03-14-2019, 03:45 PM | #11 | |
Rep 271
03-14-2019, 03:48 PM | #12 | |
Rep 1,479
Drives: 2020 M340Xi (G20)
I am interested in Blue Ridge Mountain Metallic (C35). Would you be kind enough to do your magic for that color? I'm asking because when I change the color code to C35 or any other for that matter, I get image not available Thank you very much!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA Last edited by RSnic; 03-14-2019 at 07:05 PM.. |
Jit_340i3.00 |
03-14-2019, 06:13 PM | #15 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
Me Likes!
SpenceRx243.00 |
03-14-2019, 06:15 PM | #16 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
Or this
03-14-2019, 06:17 PM | #17 |
Rep 2,699
Drives: 23 X5MC
I would think it should be up on BMWUSA any day now
03-14-2019, 06:23 PM | #18 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
That would be helpful
03-14-2019, 07:08 PM | #19 | |
I /// M FAN
424
Rep 427
themnmd1691.00 |
03-14-2019, 08:46 PM | #20 | ||
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
03-14-2019, 09:23 PM | #21 |
I /// M FAN
424
Rep 427
If compare full equipped E90 335i and full equipped G20 340i we still have 10 000 $ difference...sorry! It almost the cost of my F82...Different times different options available, but still a huge cost increase...BMW is moving the 3 series to the 5 series cost and so on...3 series market is replaced by 1 and 2 series...
03-15-2019, 01:42 AM | #22 | |
Rep 534
If you factor inflation, a 2006 330 fairly well equipped was $44k in 2016. In 2019 dollars that’s roughly $56k. A 2019 RWD M340 which comes with more items as standard than the fully equipped 2006 is $54k. So the latest model is about the same price as the e90 was. |
