03-08-2019, 10:22 PM | #1 |
Rep 63
Tire Pressure with replacements
I got my 40i with 20" RF and the spare tire option with the plan to change to NRF soon. The door plate tire pressures for the supplied Bridgestone Alenza RF are quite a bit higher than I'm used to seeing.
I'm wondering if the pressure recommendation will stay the same if I put, say, Michelin Sport non RF on? Anyone have insight? |
03-08-2019, 10:32 PM | #2 | |
Rep 6,121
Drives: 2022 Porsche Boxster GTS
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
ScotsWhaHaeWi50.50 |
03-09-2019, 04:47 AM | #3 |
Big Beaver Smile
2101
Rep 3,791
That's funny, I've also got 20" with Bridgestones and I thought the recommended pressure was much lower than I'd expect for a large tire on a heavy vehicle.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
03-09-2019, 07:06 AM | #4 | |
Rep 990
03-10-2019, 03:44 AM | #5 | |
Rep 3,406
03-10-2019, 07:22 AM | #6 | |
Rep 405
Regarding PSI - No matter the tire or vehicle I've always used the Max. pressure rating as stated on the sidewall as a guide and pressurized them at or just below Max. Wear has been great. I recently changed from 44 PSI front/back based on the door sticker to 33 fronts, 44 rears. Can't tell much difference. Here's the kicker....with the weight of the engine being borne by the front tires, why would the factory recommend they be less than the rears? |
03-10-2019, 07:44 AM | #7 |
Rep 1,785
I have the 20" Pirellis and I believe the door plate says to run 36 Front and 41 Rear. This is higher than I am used to but this is the first BMW SAV I have owned.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
03-10-2019, 07:48 AM | #8 | |
Rep 990
03-10-2019, 08:25 AM | #9 | |
Rep 405
I believe your CA is right as mine advised me that on some BMW's the spare will raise the deck it's under. Just get your regular tires come time and a can or two of a tire sealant for emergencies or enroll in AAA roadside assistance after the 4 yr. BMW term. |
mattsrs621.00 |
03-10-2019, 09:09 AM | #10 | |
Rep 1,785
Mark609166.50 |
03-10-2019, 10:46 AM | #11 |
Rep 535
After changing out my RF's on a 2015 528i after a 1000 miles to non RF's because of their non-compliant ride, I also was pleasantly surprised by the RF's on my 2018 X5 40e with 19" tires. I decided to keep them. However, I'm accustomed to getting at least 40,000 miles from non-RF tires on past autos and I am not impressed by the wear on these RF's. It looks like I'll struggle to get 30,000 miles. At 10,000 miles, I had 2 mm more wear on the rears, than fronts; so I rotated the tires. Door plate pressures maintained at all times.
