4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Want to remove the spare tire permanently - where can I get the proper cover?
      03-07-2019, 02:06 PM   #1
mcg88
Drives: g20
The car I got ended up with a few extras that I didn't particularly want/need, the spare tire being one of them. I'd like to remove it since its taking up a lot of room in the trunk.
When I remove the tire and the two pieces that hold it in place, the lid appears smaller than the area its supposed to cover with the tire gone. Is there a separate part I need to acquire to accomplish this?
      03-07-2019, 04:20 PM   #2
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
Sorry, this is not going to answer your question. I just wanted to say that if you have non-runflat tires, I'd recommend keeping it in. Typically these cars are only optioned with a spare if you have non-runflat tires. You don't want to be stuck 100 miles from home without a spare or runflat tires.
I personally am kinda OCD so I understand why you'd want to keep your trunk as open as possible, but do you actually ever use the full capacity of the trunk? Also, if you needed to expand trunk space, you could always move the spare to the back seat or plan ahead and remove it if you have to pick someone up from the airport or something.
Also, I'm curious. Would you be able to send a picture of what it looks like? I've heard the G30 is able to close normally without the spare installed.
themnmd1691.00
      03-07-2019, 10:49 PM   #3
hans007
Drives: 2020 BMW M340i
he can always get a slime and patch kit like M cars come with. lots of BMW owners do when they get rid of run flats
      03-07-2019, 10:51 PM   #4
upsidedownfunnel
Drives: 2014 335i
True. My Chevy SS came with one of those instead of a spare as it didn't have runflats. I don't know, though. If I had the option of carrying around a space saver spare, I think I would. That's just me though. I rarely put anything large in my trunk and if I do, I rarely have anyone in the back seat anyway so I can always throw the spare there if I had to.
      03-08-2019, 04:33 AM   #5
bimmer456
Drives: 340i
It may be the case the spare tire is needed to hold the weight of items placed on the trunk floor and it could collapse without it. The floor and space below it without the spare option is designed for it so won't have this problem.
      03-08-2019, 06:56 AM   #6
Calamari
Drives: 2024 G21 330d, 2008 E87 118i
Unfortunately, I cannot answer your question but I am wondering how much space does this spare tire take in the bottom of the G20's trunk?
What is an official trunk volume with the space saver tire option?
Thanks
      03-08-2019, 08:25 AM   #7
xlover
Drives: 2023 X7 40i
A couple things to problem solve....
-as noted above do check your tires and if they are not runflats think about some kind of patch kit. At a min just be aware.
-what you need is the trunk insert setup from the cars without the spare tire. The best place I can think of is to go to your dealer parts dept and explain what you are looking for. They should hopefully be able to at least identify the part numbers you need, plus if you want order or install it.
      03-13-2019, 02:52 PM   #8
daveshan
Drives: 2015 M4, 2020 M340i
Two things related to the original question:
1) You'll see a photo of the trunk without the space saver spare which I posted, plus an OEM diagram from someone else, in posts #139 and #140 here:
https://g20.bimmerpost.com/forums/sh...1555055&page=7
It looks to me like there is a fixed version of the "trunk floor" that is different than your removable version.
2) Can you please post a photo of your trunk with the spare removed for comparison?
      03-18-2019, 09:53 AM   #9
mcg88
Drives: g20
sorry for delay- bunch of pictures:
View post on imgur.com
      03-19-2019, 03:14 PM   #10
sanch8
Drives: 2019 330i
Have you looked into getting a trunk liner (OEM Accessory) from BMW? I got one just to protect the felt material in the trunk but its fits pretty snug on the floor and may solve your issue.
      03-22-2019, 08:34 AM   #11
mcg88
Drives: g20
I think these are the two trunk floor options
      03-24-2019, 07:47 PM   #12
CaliE90
CaliE90's Avatar
354
2021 M550xi  [0.00]
Go to your local dealer and ask for part #51477438290
This is the trunk liner that is in cars without the spare. You can take out everything associated with the spare and put this liner in and you're good.
http://www.realoem.com/bmw/enUS/show...diagId=51_A446
Retired- '14 F10 535i -- 3 2 1 | '08 E90 335i -- 4 3 2 1 |
      03-25-2019, 02:02 PM   #13
mcg88
Drives: g20
Thanks for the information- I just talked to my dealer and they don't see any inventory and can't seem to figure out if they can order it. Will try again next week or so
      08-22-2019, 04:57 AM   #14
cpbandit13
Germany
41
2020 BMW M340i  [0.00]
Were you ever able to get the part from the dealer?
      08-22-2019, 09:12 AM   #15
cnichols138
X3M Comp is a beast
89
Drives: 2022 BMW X3M Comp
That is the first shot I have seen under the rear floor. Ok there is a car battery there. What is the car battery in the front of the car for? Why two Batteries to begin with? Very interesting.
      08-22-2019, 11:58 AM   #16
tturedraider
tturedraider's Avatar
Drives: 2018 340i M Sport
Because there are so many electronics to keep running.
https://youtu.be/-ay-8p2p29w
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
___________________________________________
      08-23-2019, 01:43 AM   #17
Sussex_G20
Sussex_G20's Avatar
Drives: G20 330i M Sport
Cant remember a car I have owned in the last ten years that still had a battery in the front. Not like the old Beetle there is no ‘spare engine’ in the trunk/boot
      08-23-2019, 05:58 AM   #18
Eagle Creek
Part of the bimmer family!
Eagle Creek's Avatar
Netherlands
139
Drives: BMWG20; BMW E90
2019 G20 330e  [0.00]
It doesn't have one in the front.
“You can put wings on a pig, but that doesn't make it an eagle.”
      08-23-2019, 08:16 AM   #19
Jbrock22
Jbrock22's Avatar
222
Drives: 2pw
BMW   [0.00]
I have an f30 with a spare. The spare sits on top of the floor, bungee cords keep it in place and you still have all the space around the spare for stuff. The once in a while I need more space I just leave it at home. Odds are that I'm not going to get a flat that once in while.
      08-23-2019, 09:47 PM   #20
mzdial
mzdial's Avatar
Drives: '19 G20 330i & '19 G01 X3
Yes it does.
It's up near the firewall in front of the passenger side. I had my windshield changed out the other day and I didn't realize there was one there under the panel.
So I guess we have another in the trunk under the panel? I've not tried to pull it up yet.
      08-26-2019, 05:39 AM   #21
Eagle Creek
Netherlands
139
I expected only to see starter cable connecting points over there, not a full battery. Never heard about it either. Wondering what it has that..
      08-27-2019, 07:52 AM   #22
Giggler
Drives: 20' M340i, 24' X5 40i
I believe the front battery is for the vehicle electrics systems, remote ventilation, stop/start etc. The main battery is in the trunk as usual.
g20
