M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > F87 M2C transmission fluid
      03-05-2019, 09:46 AM   #1
E302F87
Drives: F87 M2C
Will be changing my manual trans fluid, called the dealer they couldn't give me any info on fluid type, anyone have any info on the fluid type? I usually run redline MTL, on my previous BMWs wondering if I still can go with MTL.
Also changing out diff fluid with redline 75/140.
M20e3087 was my old username!
      03-05-2019, 10:19 AM   #2
chip_dip19
Drives: 2018 M2
https://www.newtis.info/tisv2/a/en/f...box/1VncS3DZfy
Seems like most of the manual oils are 75w-80
      03-05-2019, 12:38 PM   #3
M Fifty
Drives: M2 & 330CI
Could you say why you need to change the fluid?
The transmission should have the - allegedly - filled for life stuff in it, while the stuff in the Diff will have been changed as part of the RIS.
The transmission is filled with this stuff:
https://www.bimmerworld.com/Fluids/D...d-1-Liter.html
The Diff is filled with this stuff:
https://www.bmwautodalys.lt/en/catal...gear-oil-msp-a
      03-05-2019, 01:51 PM   #4
RocketBoots
RocketBoots's Avatar
Drives: Horse Drawn Carriage
In the past, BMW included a manual transmission fluid change at the 1200 mile break-in for ///M cars. This was even in the car's instruction manual. They stopped the practice a few years ago. Seemed like a pure cost cutting measure, so I had BMW change mine on my dime.
While you can use Redline stuff, they have BMW branded, specific fluids. Also, I find it unlikely the dealer would be willing to use a customer sourced, aftermarket product. But I could be wrong; your dealer may be super cool
      03-05-2019, 03:01 PM   #5
M Fifty
Drives: M2 & 330CI
They did. And, when they had to pay for it, they changed fluid to something a bit longer lasting.
They might fill it with whatever you provide, on the proviso that you can't claim if it fails.
So, why is it you want to change the fill???
      03-05-2019, 04:43 PM   #6
E302F87
Drives: F87 M2C
Going from 2nd to 3rd is bit of a resistance and on cold fluid shifts are not smooth. Like other have said it used to be included. I have run redline and motul on my E30, E46 and E90 with great results. Also the car is purchased not leased and i drive it hard. So it's a cheap insurance against transmission for the long run.
DARKMTTR229.00
      04-02-2019, 04:10 PM   #7
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
38 bucks a bottle, geez that's like R35 GT-R transmission fluid prices back in the day. How many bottles does it need?
      04-02-2019, 04:52 PM   #8
FalconUSAF
FalconUSAF's Avatar
Drives: 2019 M2C, LBB, all options.
I am new to DCT -- does it have "fluid" that can be changed?
      04-02-2019, 05:11 PM   #9
M Fifty
Drives: M2 & 330CI
Yes. Although - again - why do you feel you need to? I replaced the 'filled for life' stuff on a manual E46 330ci I own. It was soot black (should apple juice coloured) on removal, and the shifts got worse as the temperature rose. D4 ATF fixed that. But, this was at 150k miles and 12 years...
      04-02-2019, 06:24 PM   #10
FalconUSAF
FalconUSAF's Avatar
Just thinking ahead 😎
m2
