M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Crazy noise while engine is off
      02-28-2019, 07:22 PM   #1
Mosely
Mosely's Avatar
594
Drives: '18 M2 | '20 X5 | '07 E92
What in the world is this noise? It happens shortly after shutting the engine off and will still be going an hour later. Been going on for a month now.
IG Photo Gallery:
instagram.com/dr_m2sko/
      03-01-2019, 03:33 PM   #2
Tano
Tano's Avatar
Hungary
375
Drives: BMW M2
Someone posted earlier a similar issue and as I remember it was caused by the VALVETRONIC actuator. Item #1
Last edited by Tano; 03-02-2019 at 03:23 PM.. Reason: Sorry, not VANOS, but VALVETRONIC.
      03-01-2019, 03:37 PM   #3
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
My M235i did this one time I remember. It went away when I started the car, I never heard it again.
      03-01-2019, 04:06 PM   #4
Mosely
Mosely's Avatar
594
Originally Posted by Tano View Post
Someone posted earlier a similar issue and as I remember it was caused by the VANOS actuator. Item #1
Interesting, as in it's a normal function or something the dealer needs to fix?
      03-01-2019, 04:07 PM   #5
Mosely
Mosely's Avatar
594
Mine seems to do it every time I drive. One time I washed my car and hadn't started it in 2+ hours and it was still making the noise.
IG Photo Gallery:
      03-01-2019, 04:14 PM   #6
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
Yep, that's when I noticed it on mine. Turned it on and off and it never did it again.
      03-02-2019, 03:28 PM   #7
Tano
Tano's Avatar
Hungary
375
Drives: BMW M2
According to the factory description: "The Valvetronic servomotor is activated via pulse-width-modulation. The duty cycle is between 5 and 98 %."
This causes the chirping noise, so it is normal. The only question is if this is normal when the engine is off, and for how long? For such an extended period is suspicious for me.
      03-03-2019, 10:40 PM   #8
TexasUp
TexasUp's Avatar
Drives: G87 M2
Mine did this for the first time last weekend while cooling down after a track session. Glad to hear it's not related, and "normal".
m2
