F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > A little ESYS assistance
GetBMWParts
      02-22-2019, 06:19 PM   #1
docCarbon
Drives: x3 35i, MaxPsi M3
After a long day at work I started my cold vehicle and smelled something burning followed by the headlights and several other items failing. Using ISTA+ I traced it to the FRM module and replaced it with one from another car. I have a working version of E-SYS and psdzdata lite, however it's been a year or more since I have used it.
With the new FRM module I can't inject the CAFD as it's from a different model and I'm sure the I-step is off. Does anyone have a link to the relevant directions for reprogramming just the FRM to my vehicle? Most I have found are for coding options. Also do I need the psdzdata full files for this?
Thanks,
Dan
      02-22-2019, 07:11 PM   #2
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Drives: BMW 316d, BMW F40 116d
If you want to flash, you need the FULL Psdzdata,
As for FRM, F30 has no FRM. Only FEM_BODY.
You want to flash your FEM?
      02-22-2019, 09:13 PM   #3
docCarbon
Thanks for the confirmation. The programming and coding on F30 forum is a little more active. The car itself is a F25.
      02-24-2019, 02:16 PM   #4
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
You should be able to inject CAFD, what does it say when injecting and coding the FRM?
      02-24-2019, 06:23 PM   #5
docCarbon
It has a CAF file on it but it's from the donor F12 that is about 6 months newer than host car. After reading and activating the VO then reading the SVT, I get the error failed to get CAFs for SWE error.
In comfort mode after entering the I step shipm and target I-step it fails to calculate the KIS/SVT target. I get the errors. errors.txt
I tried using an older psdzdata and a newer one but have the same errors.
I also tried ISTA+ but from what I've found it still requires a ICOM cable to program.
It would be nice to have headlights and turn signals back but this might be beyond my abilities. I'm assuming it's due to the I-step of the transplanted FMR being different from the I-step of the X3.
f30post
