02-12-2019, 06:03 PM | #1 |
Rep 21,240
S58 Engine: Specs and First Look!
Specs from the just revealed X3 M and X4 M (see Official Thread)
S58 Engine 473 HP (X3 M standard model) from 6250-7200 RPM 503 HP (X3 M Competition model) from 6250-7200 RPM 442 LB-FT torque from 2600-5600 RPM (X3 M standard model) and 2600-5950 RPM (X3 M Competition model) Forged crankshaft 7200 RPM redline Closed deck design Wire-arc sprayed-on iron coating for cylinder walls 3D printing technology cuts weight of cylinder heads Two mono-scroll turbochargers 350 bar maximum fuel injection pressure Valvetronic and Double-VANOS variable camshaft timing Cooling One large central radiator and two smaller radiators sides Engine oil cooler and a separate transmission oil cooler Lightweight oil sump has two separate chambers and an integrated suction channel |
02-12-2019, 06:18 PM | #2 |
Rep 468
Electric coolant pump?
"If you want a car for track use, if want to go every other weekend fight-to-fight stopwatch to your local track: go for PDK, definitely. If you use the car, maybe not on track but as a daily commuter going through traffic: take the PDK. But you want a driver's car, a fun car: take the manual. [...]"
dieselwagen0.00 |
02-12-2019, 07:26 PM | #4 |
Rep 78
Probably the same as the B58, mechanical I assume?
Engine specs here: https://x3.xbimmers.com/forums/showthread.php?t=1582854 |
02-12-2019, 07:28 PM | #5 |
Rep 2,499
I hope they increase the redline for the M3 pure. The ZF 8HP is almost assuredly the only reason they capped it at 7200. One of the specs listed for the engine show that it makes peak power between 5950-7300rpm. That could be a typo, but it could also mean the engine can have a higher redline.
kyrix1st2360.00 |
02-12-2019, 08:16 PM | #6 |
Rep 3,439
M3/M4 will have the same engine specifications as the just announced X3M/X4M, plus the M3/M4 Pure-specific detuned version.
02-12-2019, 10:33 PM | #7 |
Rep 2,349
I think the engine tuning might be identical. FWIW and just to avoid confusion, the specs are:
normal: 353kw / 480ps / 473hp comp: 375kw / 510ps / 503hp
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
02-13-2019, 12:02 AM | #8 |
Rep 2,360
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Carbon fiber strut brace optional
Looks plain compared to the one on S55. Would be interested to know how much lower the engine sits. What about the weight? No mention of lighter weight here.
Pass me if you can.
02-13-2019, 12:51 AM | #10 |
Rep 1,077
02-13-2019, 01:14 AM | #11 |
Rep 1,105
BMW is not going to release their flagship M3 a year later with the same specs as the X3M. Expect more power and more torque and a higher redline
02-13-2019, 01:59 AM | #12 |
Rep 3,439
02-13-2019, 03:37 AM | #13 | |
Rep 1,077
Doesn't anyone else think, BMW could probably rate this engine anywhere they want in a +30hp spread and it would still be accurate, and just make you feel like better about your purchase. Let me look into my crystal ball... "BMW found 5 more hp in the S58T1 through various intake and exhaust modifications to the S58 compared to last years X3 M for G80 M3 buyers, and it feels amazing like I just jizzed myself on the track in <some random place in spain> and was well worth the extra year wait and $71k MSRP" - Car and Driver |
02-13-2019, 03:49 AM | #14 | |
Rep 1,105
Do you really think that from a marketing point of view they decided to have the X3M walk with the honour of the new I6 engine, well yes for now until they release the M3 mid-2020. There is some contradictory information in the released spec sheets and if you read between the lines you know that they can squeeze more out of this engine and the redline will be at least 100 RPM higher. In my opinion this is exactly what BMW will do. The situation would be different if the M3 would also be released in the next months but we are talking about probably more than a year between the availability of the X3M and the M3. I guess that time will tell... |
02-13-2019, 03:56 AM | #15 | |
Rep 1,077
I mean m340i has more hp than the x3 m40i. The m5 had more than the x5 m. Will totally follow the pattern. It is a lot of marketing gamesmanship though. I mean I don't think anyone really thought the F30 335i made 300hp. Or the e90 335i . Those product managers and business analysts are earning their money. |
02-13-2019, 06:42 AM | #16 |
Rep 1,105
We will never get the sound of the V8 we had with the E92 M3 but I do am pleased about the sound of my F92 (2015). Not so impressive the first minute of a cold start because the cats need to be on temperature and it does sound as a lawn mower. The new model will without doubt have a particle filter just like the F92 (2018) which unfortunately further dempens the engine sound. We will see how it sounds on the X3M. Replacing the downpipes by catless downpipes is also not an option in Belgium because it will then not pass the periodic car inspection (because of the too high NOx levels). I did install the Macht Schnell Exhaust Valve Control module to control the actuators and the sound is awesome and still a headturner.
02-13-2019, 07:42 AM | #17 | |
Rep 2,360
Why ditch high rpm for low end torque? Can't see any reason other than solely employing AWD for all future M cars. Company moving towards the mundane solution to grip is the last thing I want to see on M cars. I hoped this would be R&D similar to when S50 was revised to be S54 (better sump, VANOS, and higher piston speed& engine rpm) but this is just the opposite. M division seriously needs someone at the top who pushes crazy and ingenuous ideas, not this AWDphilia.
Pass me if you can.
02-13-2019, 11:44 AM | #18 |
Rep 199
02-13-2019, 12:22 PM | #19 |
Rep 14,115
Drives: G82 M4C X-Drive
It definitely sounds similar to the S55 with an MPE.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
JTO245274.50 |
02-13-2019, 02:40 PM | #21 | |
Rep 3,439
And if someone thinks there will be a TÜ of the new S58 only a year after its initial release, they're delusional and need to take the BMW Engines 101 class one more time. |
bradleyland1503.50 JTO245274.50 |
02-13-2019, 05:10 PM | #22 | |
Rep 1,105
Imagine BMW releasing the X5M first and then releasing the M5 with the same specs? Their loyal M5 customers would not be pleased so what they did is increase it with 16 HP yet keep the torque. |
