02-11-2019, 01:44 AM | #1 |
Rep 12
Unfold Mirrors on Engine Start
Hi,
As per the title, is it possible to code the side mirrors to unfold on engine start using BimmerCode? So far I've got the following working. - Fold with Comfort Close with a 0.5 sec delay (default was 1.5sec) - Unfold at 10km/h - Not unfold with Comfort Open Ideally I'd like them to automatically open when the engine is started, or at least when the car is put into reverse. I can't see any options to do this in the main menu, but I haven't ventured into expert mode. Cheers. |
02-15-2019, 12:32 AM | #3 |
Rep 7
I'm pretty sure the method (function) for that doesn't exist. You can have the mirrors work with comfort access, or the button, but you'd have to write a method in order for them to unfold with the engine.
I'm not sure where you'd even begin with that one. Better to just let them unfold with the comfort access or speed. Set speed to whatever the lowest it'll allow you to set it to (5kph for example) and once you let go of the brake, it'll unfold. |
