02-09-2019, 07:04 AM | #1 |
Rep 27
FAM BODY error
I was in the BMW dealer and after that god trouble with the hoops on the el motor of the servo steering but I noticed that I was activated the startstop system I had previously deactivated. When I tried to go again to do this i could not access it my FEM BODY My Esys version is 3.27.1 (build 44813) and psdzdata63.3.003.I used to do this successfully in this version before.Can you help me i can not acces to my FEM_BODY I have this error:
02-09-2019, 07:26 AM | #2 |
Rep 817
Drives: bmw M3 F80
Disconnect the battery 5 min and start again
02-09-2019, 08:16 AM | #3 | |
Rep 2,302
So update your psdzdata and have fun. https://mega.nz/#F!HxZTzKDZ!VaLLlOgzuZ6kr-UoTTrl4g |
02-09-2019, 10:14 AM | #4 | |
Rep 27
i try with this but not working.i can not connect esys with this psdzdata. I find file cafd_00000794-018_070_003 to this psdzdata and copy to older psdzdata folder but i have again error |
02-09-2019, 11:18 AM | #6 |
Rep 817
Drives: bmw M3 F80
02-09-2019, 01:24 PM | #8 | |
Rep 2,302
You now have the CAFD but for coding you need more files. So please try again to use the whole psdzdata package. |
02-09-2019, 02:51 PM | #9 |
Rep 27
02-09-2019, 04:00 PM | #11 |
Rep 27
i do not know but i can not access any solution any more?
02-09-2019, 04:38 PM | #12 |
Rep 2,302
02-10-2019, 03:30 AM | #14 |
Rep 27
I still have not done anything this video shows, maybe I'm wrong about something?
https://vimeo dot com/316368660 |
02-10-2019, 03:50 AM | #15 |
Rep 27
https://vimeo dot com/316368660 https://vimeo dot com/316375340 https://vimeo dot com/316375977 i have now errors with lights i can not open doors without key and lock without key trunk with foot I have noticed this until now Please help me Last edited by F30.FAN; 02-10-2019 at 05:57 AM.. |
02-10-2019, 07:16 AM | #16 | |
Rep 2,302
On the first video up to 5:00 everything was OK and i think your problem were solved. But then you made the biggest mistake you can ever make with E-Sys. You hit the button "Code default values". This button should never be pressed. I'm not sure if your FEM_Body can still be rescued. But first you can try to "detect caf for swe". If you can choose a new CAFD then only code (not FDL code) the FEM_Body. It the coding works without any problems then disconnect your car and see if the problems were solved. Or you can try this method (post #356) https://f30.bimmerpost.com/forums/sh...php?p=12324765 And still some other points (not important now). If you want to FDL code (change single values) you need a launcher. On video Nr. 3 you have connected your car as F01 (doesn't work). |
02-10-2019, 07:59 AM | #17 |
Rep 27
02-10-2019, 08:14 AM | #18 |
Rep 2,302
Please do not press any buttons at random.
Read Vehicle Order. Read VCM at SVT Actual. Then go to FEM_Body and hit the button "Code". That's all and your problem should be solved. |
02-10-2019, 08:53 AM | #19 |
Rep 27
ahhh thanks you friend for this. I recovered the situation at the beginning I do not have any more error no errors for lights i can open a trunk with a foot keyless working again.But i can still open to code startstop system in my FEM BODY
https://vimeo dot com/316393774 https://vimeo dot com/316394097 and Is it important that I choose one of these? Last edited by F30.FAN; 02-10-2019 at 09:02 AM.. |
02-10-2019, 02:21 PM | #20 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Don't you use premium launcher?
Esys alone won't let you code I think... |
02-10-2019, 09:09 PM | #21 |
Rep 2,302
02-11-2019, 08:37 AM | #22 | |
Rep 27
I wont to turnoff start stop system. When i press EDIT FDL i recived messages No ESF file chosen[C155] |
