F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DME replacement Part# questiosn
proTUNING Freaks
      02-09-2019, 05:14 AM   #1
THbimmer
TH320i
Thailand
23
Drives: 2012 320i f30 -
Exclamation DME replacement Part# questiosn
this is my current dme unit in the car which needs to be replaced.
View post on imgur.com
and this one is the replacement that i have found locally...
are these two interchangeable ? i have read so much stuff online about the version types and different ones for different countries so i really am confused...
Any help much appreciated, Thank you !!!
2012 BMW 320i - Catless DP - Full 3" exhaust system - Cold Air Intake - S55plugs - GFB DV+ - ProjectA Stage 2 Remap (270 hp on E20).
      02-10-2019, 08:19 PM   #2
Levanime
BimECU
Levanime's Avatar
2007 BMW 335  [0.00]
both are MEVD1724
If cloned should not be a problem
      02-10-2019, 08:26 PM   #3
justanurse
justanurse's Avatar
Drives: 2011 M3 6sp
2014 BMW 328i  [0.00]
Originally Posted by Levanime View Post
both are MEVD1724
This^ just make sure it's done right and should be a easy fix.
      02-22-2019, 02:11 AM   #4
THbimmer
TH320i
Thailand
23
Thanks guys! just got the unit and will try to get it cloned by my local indy. Cheers!
      02-22-2019, 10:49 AM   #5
huwang14
Drives: 3 Series F30 328i
so good!!!
Tags
dme, ecu, n20, replacement
f30post
