BMW M3 Forum (E90 E92)
BPM
      02-02-2019, 07:18 AM   #1
Theodore
Theodore's Avatar
Drives: 2011.5 E92 M3
DIY: Diagnose E9X M3 Clunking or Popping Noises
If your E9X M3 has an undiagnosed clunking or popping noise, check these items out as the most common failure points.
If the clunk noise occurs in conjunction with turning the wheel, check on the strut bearings and the sway bar end links.
This video does a great job a showing what happens when a strut bearing fails (skip to 1:00 mark to see failure in action):
This video does a great job a showing what happens when a sway bar end link fails:
It's worth checking on your car's driveshaft components to include the Guibo (aka flex disc). Here is a good video example of a Guibo that is failing:
And a failing driveshaft center support (skip to 0:56 minute mark to see the acceleration behavior from a stop):
What I Wish I Knew When I First Bought My E9X M3 Can Be Found Here
E9X M3 Exact Original Equipment (OE) Equivalent Parts Can Be Found Here
E9X M3 Common Torque Specs Can Be Found Here
E9X M3 "Factory" Tools Can Be Found Here
m3post
