02-01-2019, 06:13 PM | #1 |
Rep 171
Drives: X3 M Comp
NBT Evo Retrofitted in 335 F30
So I purchased a NBT Evo retrofit from bimmertech and just got the last bit of everything installed and finished my coding session yesterday evening. Everything is working great, the new navigation with the latest maps are freaking amazing. Install was time consuming, but all in all it wasn't bad. I will update this thread with some pics, I didn't get many during the actual install because I was trying to get everything done as quick as I can. I did most of the work in one evening, probably like 3.5 hours. I did have to go back the next day and work out a few issues that were resolved.
So the point of this post is mostly surrounding coding. I emailed after the fact asking what if anything I would notice differently and asked details of the coding, of which they expressed they can't say the details. Mostly that the coding was to make sure everything was installed properly. My existing coding was overwritten, so I'll have to go through and do that again, or indicate what I had done and they said I could do another coding session. The technician did add back the Sport+ when I mentioned it wasn't there, so that was cool. My question, now that my car mostly has a NBT EVO what if anything will I notice if I connect to my car and can code anything? Should I treat any coding (which I may not even need to do) as if I have a NBT Evo now or still the CIC? I did get updates to the HUD and the exit ramps etc. It's so much better than the CIC experience I had. Like literally they're so much better! -NVE |
02-01-2019, 06:46 PM | #2 |
Rep 10,256
What year vehicle do you have?
If for some reason the vehicle has to be reprogrammed as advised by BMW AG while serviced by the dealer, the equipment will not match the as-delivered state. The reprogramming process may not complete successfully. It's not a big problem as reprogramming bulletins are rare. |
02-01-2019, 07:01 PM | #3 | |
Rep 171
Drives: X3 M Comp
-NVE |
