F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > ECUs Missing in TAL Processing
Studio RSR
      01-31-2019, 07:21 PM   #1
iRoik
Australia
Drives: F10 535i
2012 BMW 535i  [0.00]
Hi guys, looking for some insight here.
Previously I installed BM3, which broke a lot of things and I was advised to update all my ECUs. I did that and it fixed all my issues so I assumed that I was on the latest version of the firmware.
I was coding and wanted to enable some things such as Compass in my Kombi, but realized that my firmware was too old. Upon digging, I discovered that I needed cafd_00000069.caf.010xxxx for it to work, but was currently on cafd_00000069.caf.009xxx.
This sounded strange as I thought I had updated my ECUs successfully. I can confirm that I've got the latest psdzdata, I've checked and the cafd_00000069.caf.010xxxx file exists in there
So I brought up ESYS and it is telling me I am still on:
Using this guide http://www.bmwesys.com/guides/E-Sys%...CU%20Guide.pdf, I went to update my ECUs, however it isn't showing me any ECUs
Vehicle is a 2012.03 F10 535i, but I posted here since the f30 forums are generally more active.
Thanks in advance!
      02-01-2019, 03:26 AM   #2
atzebmw
Germany
588
Drives: Tesla Model 3
Which E-Sys version do you use?
First i would try to use another version (3.27 is still most recommended).
      02-01-2019, 05:47 PM   #3
iRoik
Australia
Drives: F10 535i
Thanks for the suggestion, I'm currently using 3.27.1
      02-01-2019, 06:49 PM   #4
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Thanks in advance!
I hope the problem will be solved.
It's interesting that you are not the first forum member to mention that F3x community is more active than other communities.
      02-01-2019, 11:33 PM   #5
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
If you have "update VCM" unchecked in options, then, I-Step will not change.
      02-03-2019, 06:45 PM   #6
iRoik
Australia
Drives: F10 535i
Good catch, the I-Step didn't change because that setting was unticked. Is there any other way I can tell if I have the latest firmware? I can see newer CAFD files in my psdzdata, but they weren't updated to my car. Any chance that I would potentially have to do incremental upgrades up to the latest one?
I'm looking for the latest CAFD so that I can (potentially) enable a compass in my Kombi
Thanks
      02-03-2019, 06:53 PM   #7
Almaretto
Almaretto's Avatar
2374
Thanks
Just running TAL calculation and checking for SWFL changes.
You can also write updated I-step to car after flashing with VCM tab.
iRoik4.00
      02-03-2019, 07:00 PM   #8
iRoik
Australia
Drives: F10 535i
Thank you, I'll give it a shot when I have some free time. Is it safe to assume that whatever CAFD version is in my psdzdata should be updated to the ECU?
      02-03-2019, 07:19 PM   #9
Almaretto
Almaretto's Avatar
2374
Yes. Sometimes highest numbers are not always selected for injection.
iRoik4.00
      02-03-2019, 07:26 PM   #10
iRoik
Australia
Drives: F10 535i
I'll let you know how I go. Yes interesting but I suppose not surprising. F3x outsell all other models, hence the larger user base
Cheers. I'll try again over the next few days when I have a moment
f30post
