F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > "No Signal' Corrupt coding data
ARMA SPEED
      01-24-2019, 09:38 PM   #1
Paul Koury
Drives: 2016 430I f33 Convertible
Help Needed...Head Unit crashed..Yesterday I tried coding with the Bimmer app using a cheat sheet in expert mode and received a ECU corrupt: Cannot be coded..I tried restoring from a backup but no luck...Decided to connect via Esys to see the problem was seems that i haver 2 instances running on the same ECU..How can I restore the corrupt HU_NBT ECU or repair this one...Pics below..Thank you
      01-24-2019, 10:05 PM   #2
atzebmw
Germany
588
Drives: Tesla Model 3
Did you choose "F033" at the start of the premium launcher?
      01-24-2019, 10:50 PM   #3
Paul Koury
Yes I do
      01-25-2019, 05:09 PM   #4
Beemn Milan
Beemn Milan's Avatar
New Zealand
11
Drives: F36 435i GC/JCW Works Cup Car
I actually had that happen to me without any doing any coding at all, NBT unit had a fault and had to be replaced, would just come up no signal
      01-30-2019, 12:03 PM   #5
steve@codemybimmer
BimmerPost Supporting Vendor
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Check the log under C:\Data\ and see what the "More than one condition is active " part fully says. It may point to something.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
f30post
