M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Speakers blown in brand new M2C
      01-24-2019, 06:45 PM   #1
tokki
Drives: M2C
Hi guys, I turned on my car today and was instantly greeting with very loud booming and crackling coming from the speakers. The sound continued for a few minutes regardless of whether I had the volume muted or not. Now, theres no more crackling but I have no speaker functionality whatsoever. Rainy and moist day here in New Brunswick, Canada. I'm guessing moisture got in somewhere and created a short. Anyone have any advice?
2019 M2C Sunset Orange 6MT
Eventuri Intakes
Eisenmann Valved Full Exhaust
      01-24-2019, 08:09 PM   #2
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
Had a similar problem in my M235i. It would happen randomly, but would self correct after turning off the car for an extended period of time. On the next start up everything was fine. Have you tried parking it for a few hours and retrying?
      01-25-2019, 12:26 AM   #3
tokki
Drives: M2C
I'll def try again tomorrow but the way it sounded through the speakers, I feel like some sort of damage took place. Thanks for the advice!
Eventuri Intakes
      01-25-2019, 01:50 AM   #4
Philb65
Drives: LBB M2
Sounds like water/moisture has got in the amp. Well known problem, the crackling and booming can be ear splitting and puts the shits up you when it happens. There’s a vent directly above the amp left hand rear arch which is poor design imo, have a check if it’s dry in there. Trip to the dealership as it won’t get any better, had my amp swapped last year and now my ASD module has gone pop.
      01-25-2019, 10:25 AM   #5
tokki
Drives: M2C
That was my initial prediction. You're right, my gf who was in the car with me thought the car was blowing up lol. Definitely made us jump.
Easiest way to get access to the amp? Through the trunk?
Eventuri Intakes
      01-25-2019, 10:44 AM   #6
Philb65
Drives: LBB M2
Yep this guide for fitting the ASD bypass harness is good.
https://www.2addicts.com/forums/show....php?t=1202389
      01-25-2019, 10:48 AM   #7
tokki
Drives: M2C
Thanks! In case the amp is toast, what are the chances my speakers are too?
Eventuri Intakes
      01-25-2019, 11:51 AM   #8
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
This is the link I was going to send. It says to remove the trunk seal to get the back plate out. Don't do that! It's a super huge pain in the ass to get the seal back on. You can remove the back plate without removing the trunk seal. This will make your life much easier when it's time to put it all back together.
Then again, why pull it all apart anyway? It's under warranty, let the dealer figure it out.
      01-25-2019, 12:23 PM   #9
K8_M235i
K8_M235i's Avatar
Drives: CM E36
Definitely sounds like the amp problem. It's pretty well documented
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM
1995 E36 M3 Sunbelt S52
      01-25-2019, 12:30 PM   #10
Philb65
Drives: LBB M2
Your speakers will probably be ok, mine had a good work out when my amp went but they mostly seem fine.
Now the ASD is playing up I’ve got noise from the sub under the seat so not sure if it’s the ASD module or the speakers given up. Will find out on the 1st feb when the dealer has a look.
      01-25-2019, 01:25 PM   #11
tokki
Drives: M2C
Thanks again man, I will report my findings as well once I get my dealer to take a look in a couple weeks.
Eventuri Intakes
      02-12-2019, 11:08 PM   #12
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
Just had my 2018 in for weird speaker noises, they replaced the amp, after first pulling off both door panels and swapping speakers between them, and then temporarily re-pinning the harness back at the amp (to make sure it wasn't wiring, I guess).
After they finished their troubleshooting, then I guess the new amp was approved and now everything is working again... except they re-coded the car so some of my shit was factory defaulted again.
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice.
I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway.
I'm also a fan of aural pleasure.
      02-14-2019, 04:02 PM   #13
tokki
Drives: M2C
Yep, dealer replaced my amp and everythings working again.. For now.
Eventuri Intakes
m2
