01-14-2019, 10:45 AM | #1 |
Not stock
474
Rep 614
Understanding coding terminology?
There may already be a thread about this but I've been using Bimmercode for simple stuff, but want to get into doing some more (perhaps M Perf brakes, M Sport wheel, etc.)
I don't fully understand what "VO" means. I don't really get FSC or some of the other terms. Is there a thread or post out there that clearly describes what it means to "VO Code" is vs. FSC or ... the other commonly used terms? Thanks!
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
01-14-2019, 12:13 PM | #2 | |
Rep 202
Drives: 2011 M3 6sp
VO is vehicle order and when you vo code you are adding a option code to your car and intending to code the modules that are required to make use of this new option option code you added to your vehicle order. FDL coding is just coding a single option inside a single ECU and actually when you VO CODE the computer is doing a bunch of FDL CODE for you I. The ECU you select. Like for example I added 2TB sport automatic transition to my vehicle order and coded the modules that were involved with 2TB, BUT I do not have paddles so I manually went into the module that had the FDL code to activate paddles so I could turn it off (because 2TB turns it to active because it assumes you have paddles) FSC codes I am not exactly sure on all I believe I known is that it's sort of a lock which only opens when matched to its original vin. Like there's three FSC code that belong to NAVIGATION and if they are rejected then the navigation will be grayed out on idrive, though this can be bypassed if you have a emulator because it will allow the NBT to keep its donor vin and thus there won't be a mismatch between the FSC codes and vin if you have a retrofitted NBT |
01-14-2019, 01:07 PM | #3 |
Not stock
474
Rep 614
Ok - interesting. Very helpful! So, if I ever sell my car some day, is there a way to apply the original, non-tampered "VO" profile back? Like, I know what I coded, generally, but if I ever want to reset it to "Whatever it came with before I messed with it" is there a VO built into the car some place that defines the packages it had?
I understand now though, so very helpful. So for instance if I got an M Sport wheel I could VO code 2BT (my car actually has 2BT... but this is hypothetical) and that'd enable trans program as well as paddles vs. having to go do FDL on both the trans and the paddles?
01-14-2019, 06:20 PM | #4 | |
Rep 202
Drives: 2011 M3 6sp
and 2TB? and yes absolutely, the paddles themselves you dont code the coding is a part of the FEM so that is that one you would go in to FDL code whether you want paddles on or not. I dont have the file to install anymore but search up the NcdCafdTool, you can load up your cars original VO and you can checkbox an option to see what codes it will change/the modules you need to VO code to get it working properly. Last edited by justanurse; 01-14-2019 at 06:24 PM.. Reason: extra info |
5mall5nail5474.00 |
01-14-2019, 07:07 PM | #5 | |
Not stock
474
Rep 614
One last question - since I already coded w/ Bimmercode (FDLs, I guess) is there anyway to get the "original" config pre-me coding with Bimmercode? What does "FA" mean and what are CAFD files?
01-14-2019, 07:16 PM | #6 | |
Rep 202
Drives: 2011 M3 6sp
and FA is just the same as VO they are interchangeable last time I checked CAFD files I'm not sure exactly the definition but I can give you an example of how they're applied. Basically when you go to retrofit something the ECU from the donor car still has the old cars CAFD, when you retrofit it you're most likely going to have to inject YOUR cars CAFD into it to get it working properly. For example: I went to go retrofit a KOMBI (instrument cluster) which was pre owned so I opened it up and cleared the VIN so I could write my vin to the KOMBI. Just for fun I plugged it in without any coding and immediately it came to life BUT since it was for a different model BMW the gauges did not work and there were a bunch of error lights on dash and it basically thought it was still the old car, even had a picture of the old car on it when it started up. AFTER injecting my cars cafd into it all the gauges came to life, errors went away (like it thinking I had a sunroof disappeared), and it showed a picture of MY car. |
10-08-2021, 03:03 AM | #7 |
Rep 18
Hi,
I've read all your posts. Could someone explain or point to some resources about this issue on 2020 X6 M50i. The car has some autopilot features that are disabled in certain countries and enabled in Germany. For example Route details (autopilot reduces speed if a roundabouts ahead), speed limit adoption (autopilot corrects speed according to signs), trafic lights recognition (autopilot stops in red light) etc. I am sure that should be corrected thru coding. Any ideas or help would be much appreciated! Thanks |
10-08-2021, 08:26 AM | #8 |
Rep 525
BMW have released TLA on production vehicles
The new features are: Traffic Light Assistant Traffic Light Recognition warning - monitors for light change from Red to green and warns driver to set off if not paying attention Active Lane Guidance - Prompts to change auto change lane (indicator stalk) when following nav, in preparation for an exit, including the actual exit manoeuvre No overtake on left/right side - not a good feature Emergency Lane assistant - for 2 lane + carriageways where the speed is < approx 30mph. Moves the car to the far side of the lane to allow emergency vehicles to pass more easily Auto distance adjustment based on conditions aSLA Pre-requisites: i-drive 7 full vehicles only e.g. G05/G07, G20, G15, G30 (LCI), G11, etc 5AU DAP aSLA i-step 11/2020 + esysx: latest available if poss, but must support i-step 07/2020 mappings Important Note: not every region is supported. If you code it exactly right and TLA states no available in your country, then its blocked at a lower level.
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
10-08-2021, 08:55 AM | #9 | |
Rep 31
Current cars: 2016 F13 640XD ; 2017 F36 420XD
Past cars: 2010 E93 320i ; 2008 E60 530XD ; 2006 E90 320D |
