BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > 12V under closed car
      01-08-2019, 01:29 AM   #1
zorro101
Drives: 116d
Hi
My car has no anti-theft and I would like to insert a blinking LED to make it look like there is an alarm.
to do this I need to find 12v that are present only when the car is closed with the remote control and remain in this state until it is opened again with the remote control.
is there any way to find this 12v?
My car has no accessories, no Central Information Display
thanks
besth regards
      01-08-2019, 07:25 AM   #2
emil111
emil111's Avatar
Romania
44
Drives: BMW 114d
if your car has no accessories then its good news because nobody will steal it or parts from it,if you are worried about people breaking inside to hopefully find goods you left inside then i advise getting tints on all the windows and yes i know that under EU law the front windows must have a vlt of 70% window+tint but there are many tints that companies that produce tint light tints.
get the windows tinted,it will not only keep burglars away (no its not like an impenetrable wall but it is harder to snatch things from inside a car if it has tint applied on the windows) but it willl also help reduce the heat and make your car look nicer .Dont forget to go for good quality tint and i recommend getting atleast a metallized film installed
Bmw 114d
Honda Jazz
Daewoo Matiz
Daewoo Nubira II
      01-08-2019, 07:58 AM   #3
zorro101
Drives: 116d
thanks for reply
personally i don't like the windows tinted
there will also be a wire with 12v under car closure
thanks again
      01-08-2019, 01:36 PM   #4
No one
Drives: F21 118i
This is so nice. Why don't you simply attach a note like "Don't do it, please!"?
Just as a side note, are you reasonably sure it will work at all (aren't shy thieves an extinct species)? By the way, security systems that silently send an alarm signal to the owner or intruder handling specialists don't indicate that (to let the visitor stay for the appointment ) - lacking the indicator does not really prove the car is not protected (the true "clients" aren't expected to know that though ).
Are you sure it's all you need? Consider DIY threads like this one: DIY: F30 OEM Alarm Retrofit (320i/328i) or address alarm retrofitters, perhaps.
So it has the best theft protection, actually.
"Knowledge only increases sorrow".
      01-08-2019, 02:00 PM   #5
No one
Drives: F21 118i
"Hopefully": making it hard to see there are no goods only increases those hopes/curiosity.
Tinted, really? Why so? The security (armour) films you appear to describe aren't necessarily tinted (if at all).
Why? Dark colours accumulate heat as everybody should know from school physics/optics basics. "Solar control glass is not necessarily coloured or mirrored glass."
it willl also make your car look nicer
Not necessarily: only by concealing your face, perhaps.
      01-10-2019, 02:52 AM   #6
zorro101
Drives: 116d
i can't
I do not have the extended ceiling light, but the base one
      01-10-2019, 06:12 AM   #7
No one
Drives: F21 118i
i can't
What made you think the extended ceiling light was mandatory? It doesn't look like you have to have the light package: in the configurator alarm is independent from it. Nor parts catalogue mentions a dependency:
      01-10-2019, 08:32 AM   #8
zorro101
Drives: 116d
What made you think the extended ceiling light was mandatory? It doesn't look like you have to have the light package: in the configurator alarm is independent from it. Nor parts catalogue mentions a dependency:...
it seems that there is need for something else:
https://www.newtis.info/tisv2/a/en/f...ystem/FpcQ82al
A21 -> Roof function centre
https://www.newtis.info/tisv2/a/en/f...sha/1VnXlbFqeM
https://www.newtis.info/tisv2/a/en/f...n-sha/GFoyuoye
I'm not sure it can be fitted
I have to study
      01-11-2019, 06:01 AM   #9
zorro101
Drives: 116d
I have to study
confirm
is mandatory to add "roof function center" impossible for my car
there is the carpet at that point !!!
      01-11-2019, 07:59 PM   #10
No one
Drives: F21 118i
confirm
This is too sad to be true. They appear to offer an OEM alarm retrofit for some cars. Yours is an LCI, I see. Feel free to check if they do suggest it's protected enough already (and you shouldn't worry that much, at the very least).
      01-14-2019, 01:24 AM   #11
zorro101
Drives: 116d
yes is firs F20 series!
for that I just wanted to put a bollard
thanks again
1addicts
