BMW X5
      01-05-2019, 09:37 PM   #1
Doc5513
Drives: X5
Hey guys,
This is a bit of a double post since I posted the same in the F15 section...but this is all going down next weekend and I'm super confused.
Here's the deal:
I have an '16 F15 at the end of a 3/36. This is my first BMW and first lease.
The lease was done in Sept, but extended as I've been waiting on the G05 on order. I currently have 39k miles on the original runflats.
I understand I will be responsible to have new tires on the vehicle at return *if* the current tread is below the cutoff. And have been told that it is VERY LIKELY with 39k I am above cutoff.
But when I posted on the other side many guys said they got a pass on buying tires bc they were leasing again. But my current CA says that just isn't the case..that the lease return folks are separate from him and he has no control over that. Also , for what it's worth, I'm turning lease in to a different dealer than it came from.
Can folks share their experiences in this process? Any strategies ?
And if they nail me for tires, Is there a certain less expensive tire option I should preemptively purchase?
Thanks
      01-05-2019, 10:40 PM   #2
proveg
Drives: 19X5
Originally Posted by Doc5513 View Post
Hey guys,
Here's the deal:
Thanks
From what I researched and experienced, you are required to have all 4 tires of same brand on the car with same load, size and speed rating.
In order to not have to buy replacement tires you must have at least 2/32 thread depth.
If you are not passing inspection from what I understand CA can't do anything and you have to talk to finance department to see if they could do something.
The only time you might be able to ask CA for help if you didn't get inspected prior to return, they may look the other way.
      01-05-2019, 11:20 PM   #3
Refujeet
Drives: X7
He technically can't do anything...but be can do something, if he wants.
For example, he can get tires for you from the parts department at cost, or at least discounted. Or he can eat some of the cost of the tires from the margin on the new vehicle...
      01-06-2019, 01:29 AM   #4
bubbahead
Drives: 2022 G05 40i Msport
Go buy used tires on kijiji. Otherwise you will be dinged a good chunk of money. This is reason I get wear-tear option
2018 540ix msport
2015 X5 msport
2013 750ix msport
2011 550ix msport
2009 e92 335i msport
      01-06-2019, 10:03 AM   #5
ted99
Drives: former i3>330e, 528i>X5>530e
It's 4/32, or 1/8" for the wear limit. I'm monitoring my wear carefully. Just rotated back to fronts at 12K miles as the rears had 2mm greater wear. If it looks like I'm going to hit the wear limit for turn in, I'm going to purchase a set of non run flats, change the tires and save the originals that still have enough tread to pass inspection. I'll change them back just before turn in, and i'll have a good set of non run flats to put on the next car. I did this with my 528 and it worked out well. I'm NOT going to buy a new set of tires for BMW to make up for the inferior wear run flats they provide as OEM.
      01-06-2019, 11:41 AM   #6
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
What is crazy is 4/32 is basically worn out so if they take it back at 4/32 what is the difference vs 2/32 or 3/32 car still need tires and if they CPO and resell it will get new tires.
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      01-07-2019, 05:44 PM   #7
Arctic_X5
Drives: 2019 BMW X5
Go on ebay and you'll find some used tires with still good thread on them. BMW doesn't care if the tires are used when you return the car. As long as the tires are the same spec and have good tread life left. You would just need to email or fax BMW the invoice when you buy the tires.
      01-07-2019, 06:45 PM   #8
Carpe_BM
Drives: EX-BMW (2019 BMW X5 xDrive40i)
how the hell did you get 39K out of RFTs?!?!?!
ted99242.00
      01-07-2019, 07:55 PM   #9
screamace
screamace's Avatar
Drives: 2020 BMW X5M Competition
My question exactly. We are getting close to the end of 3/30 lease and I have saved the OEM run-flats at limit, and my subsequent non-RFTs are pretty much done too.
2019 Porsche Panamera 4 E-Hybrid
Past BMW: 2018 M550i, 2016 X5 40e, 2014 335xi, 2011 X5 50i, 2010 550i
      01-07-2019, 08:14 PM   #10
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
I always help out my lease return clients. We often buy these cars from BMW to certify and have as used inventory. The client doesn't get charged and we keep a loyal happy client.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      01-07-2019, 08:19 PM   #11
denniss
denniss's Avatar
392
My front tires had no thread. I return my car to the same dealer where I got my new car. And they never charged me as they sold my car a week later with new front tires.
2022 x4mc (gone)
2019 X5 40i M-Sport (gone)
2016 X5 35i M-Sport (gone)
xbimmers
