Aux Jack Stopped Working
12-28-2018, 09:48 PM | #1 |
Rep 3,189
2011 E90 with Professional head unit. Aux jack worked yesterday, doesn't today. I have been using it to play my phones audio for the last 4 years with no issues. USB port next to it works, cigarette lighter port next to it works, bluetooth still works.
I have tried a brand new cable and a different phone, neither worked. The phones do not recognize that something is plugged into the phones aux jack. If I wiggle the aux connector in the phone I can hear crackling through the cars speakers. I popped the aux/USB ports out and the connection is clean. Pulled the radio and no issue with wiring or any obvious issue. I am at a dead end now on what to try next. |
12-29-2018, 09:33 AM | #2 | |
Rep 151
12-29-2018, 05:52 PM | #4 |
Rep 3,189
Head unit is fine. I went into the trunk and disconnected/reconnected the Mulf 2 and now it works again. Have to have the aux jack in a special orientation in the phone to get full sound, but it works.
12-29-2018, 06:20 PM | #5 | |
Rep 4,031
Plugging/UNplugging 3.5mm jack into female socket for 4 years has probably worn or broken something in the socket, hence the static when manipulating the jack in the socket. The Aux & USB connectors are fragile, and the best approach for regular use is to plug an extension cable into each and leave it connected, transferring regular connect/disconnect wear to the extension jack. Without knowing exactly what radio option you have, I can't be sure the following is the correct wiring diagram, but one would reasonably expect it to be. Three wires at Aux socket: Left Channel signal (White), Right Channel Signal (Gray), & Shielded common ground, all going to Pins 4, 3, & 2 respectively of Connector X18807 as shown in this TIS Schematic: https://www.newtis.info/tisv2/a/en/e...i-lim/BtvlHOM5 If you have NOT done so, I would suggest removing the Aux socket, using patch cables to tap input into the three wires of Connector X18807, disconnected from the socket (bypassing any mechanical part of the socket) and seeing if you get output from the Audio with Aux selected as the input. You can just test each channel separately, two wires at a time. George |
12-30-2018, 12:20 AM | #6 | |
Rep 3,189
