Brake Pedal Firmness After Bleed
12-25-2018, 11:05 PM | #1 |
Rep 141
I recently replaced rotors and pads with zimmermann/akebono OEM replacements. After that process, I bled the brakes with an actron vacuum pump. Can confirm I never let the level below minimum. My pedal does not feel as firm as before. I do not get the initial bite I had before as well, but guessing that is due to brakes needing to be broken in. The pedal is not super soft and definitely works well (for bed in).
Now, I am guessing I need to bleed my ABS pump. Is there any way I can do this without taking off all my wheels and going corner by corner again? Basically, any way to just activate it like coolant bleed? I have heard INPA, but not sure if that functionality is what I want to do (the route of not removing everything). Also, would bimmergeeks protool do the trick? Thanks! |
12-26-2018, 08:12 AM | #2 |
Rep 2,243
Drives: 2007 328i / 2014 M235i
You shouldn’t need to bleed your abs unless you replace it. I always do gravity bleed then do a few manual bleed operations. Tap the calipers with deadblow to remove any air bubbles
12-26-2018, 09:12 AM | #3 |
Rep 245
Your brakes will always feel slightly soft immediately after bleeding them. If it's been more than a couple of days since you've done the procedure I would look into re-bleeding. Otherwise give it a couple of days and the pedal should firm up.
12-26-2018, 11:24 AM | #4 |
Rep 666
My brakes felt the same way after replacing them with akebonos on my 5 series. My buddy too had the same experience on his M5 and hated it so much that he went with the OEM Pagid pads. No issues after that. I'm thinking of ditching them as well; they make the car feel not nearly as aggressive.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
NathanK2433.00 |
12-26-2018, 03:33 PM | #5 |
Rep 141
Thanks for all your input. I'm gonna give them a few days and see if it gets any better. Definitely not awful at the moment, just not impressed at this point in the break in.
By the way, on my road trip today I kept hearing a clicking noise coming from the driver front wheel well during braking. This got faster/slower with wheel speed. I assumed my pads were rattling, but then halfway through the drive I got minimum pad thickness warning. Could that mean my sensor was clicking against rotor and ultimately came loose or somehow made a ground with an unintended piece of metal, therefore setting the fault? Brake performance did not change and no smoke, smells, etc. |
12-26-2018, 03:39 PM | #6 | |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Either way check it, the sensor is grounding on something it shouldn't.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
12-26-2018, 08:29 PM | #10 |
Rep 141
Before doing my pads and rotors I took some fluid out of the reservoir. It was a bit dirty and around the time my fluid needed to be done. Also, thought it would increase pedal firmness after hardware swap. Really just fell around same time, and had free time because holidays.
12-26-2018, 09:22 PM | #11 |
Rep 28
after changing rotor and pads brakes where soft. gave it day or two still soft. first car I had to bleed after not opening the system. when I bled the brakes air came out, go figure. buddy said something about a seal rolling or sumthin idk.
12-27-2018, 08:11 PM | #12 |
Rep 141
After a few days and a little ABS in the ice, my pedal is back to normal firmness. Still gotta look into that sensor I mentioned.
01-01-2019, 08:09 PM | #13 |
Rep 141
If anyone was curious, it was the sensor. The part that connects to the pad did not come loose, but the inside of the wheel was hitting the sensor cable. This basically cut it open, and exposed the wiring. Hopefully picking up a new one tomorrow and routing it more carefully.
