Spark plug stuck in the head
12-24-2018, 08:34 PM | #1 |
Rep 24
So i bought all new spark plugs and coils, I bough a spark plug socket specifaclly for the n54 since it needs a special socket. Every spark plug came out easy besides the last of course. When i would go put the socket on the plug, the socket wont not go on if it wasnt the right socket but it was. I looked at the 12 point on the plug and it looked rusted and stripped. I took a 11 mm socket and put jb weld in it and slid it into the plug hoping it will bond and let me take the plug out. 24 hours later and i tried to take the spark plug out and right away it snapped free, but not the plug. The top half of the plug broke off. The thing is there is till the center piece left in the bottom, so what is stuck isnt hollow and i dont know how to take it out. please help!
12-24-2018, 08:42 PM | #2 |
Rep 78
The Ford community has some experience with broken plugs, maybe look there for some guidance. One trick my mechanic friend taught me is give it a little twist in the tighten direction first. I am still skeptical but he has removed 1000's more plugs that I have so.. respect. The theory is a twist in the clockwise direction breaks free some of the carbon and allows for easier removal.
I have dealt with the ford plugs that just shoot out.. a model year later they just snap off I guess. Haven't had that pleasure personally but here: http://www.fourwheeler.com/how-to/en...8-spark-plugs/ |
unrulyteach392.00 |
12-24-2018, 08:53 PM | #4 | |
Rep 24
12-24-2018, 09:09 PM | #7 |
Rep 13,103
12-24-2018, 09:19 PM | #9 | |
Rep 24
12-24-2018, 10:21 PM | #10 |
Rep 445
I don't see any way you safely fix that without removing the head. If the ceramic came completely out (which is near imposslble, since it is crimped into the steel outer piece), you could use the easy out. With the ceramic still in there, the easy out will not go in. Break the ceramic, and small pieces go into the cylinder, where they WILL do damage to the pistons, rings, and bores, likely trashing the whole engine. Ceramic is very, VERY hard - much harder than steel.
Regards, Ray L. |
12-24-2018, 10:40 PM | #11 | |
Rep 6,290
Or close the exhaust valves and shoot air and vacuum attachment on the intake valve side? |
12-24-2018, 11:15 PM | #12 | ||
Rep 193
12-25-2018, 12:43 AM | #13 | |||
Rep 2,202
Subbed.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
12-25-2018, 02:34 AM | #14 |
Rep 13,103
Vacuuming the area and making sure its clean would be the first thing to
do on . If you get it to spin I would vacuum again before removing all the way. https://www.championautoparts.com/Te...park-Plug.html Gets some knocker loose or crc foam seems to be the conclusion. Last edited by ctuna; 12-25-2018 at 03:39 AM.. |
Fritzer944.50 |
12-25-2018, 09:27 AM | #15 | |
Rep 24
12-25-2018, 09:31 AM | #16 | ||||
Rep 193
Might not see it on the camera. Once again, best of luck. Shitty situation for sure |
PichaDis11295.00 |
12-25-2018, 10:19 AM | #18 | |
Rep 18,733
Here's what I'd try first. - Remove the right-side struct brace to get as much working room as possible. The bolthead on the cowl is a 18 Torx socket IIRC. A 9/16ths 12-point socket works as well. - Buy a vernier caliper to measure the various diameters you'll need to measure. - Take an old plug and cut it open in similar fashion to how the broken plug is situated. You can then get the measurements of the inside of the plug body and ceramic insulator, rather than guessing. - If the ceramic is still in the body, you will probably need to drill it to the proper diameter for the easy out. Used a drill bit meant to drill glass/ceramics, or concrete as a last resort. I'd try to drill out the entire ceramic insulator and get to the metal body that is the remaining threaded plug body. - Practice. Set the plug you cut up in a vice. Practice drilling the ceramic and getting the easyout to bite into the remaining material. - Soak the plug in the head for a day with penetrating oil. I prefer Kroil, but you can only order it on line. PB Blaster is pretty good too. - Once the plug is out, I don't see why TheMidnightNarwhal suggestion of vacuuming the cylinder out would not work as long as the cylinder remains dry. If you vacuum the cylinder either use a rubber/plastic hose attached to a vacuum cleaner or rig up something that threads (plugs in the hole - like a rubber cork drilled in the center to accept the vacuum tubing) in the plug hole to get a real good vacuum on it. As long as you don't rotate the engine any ceramic pieces would hurt anything just sitting in the cylinder. If that doesn't work, then pull the head and let an automotive machine shop remove the plug. Good luck with it.
12-25-2018, 10:49 AM | #19 | |
Rep 445
Removing the head is the ONLY safe way to fix this. Regards, Ray L. |
ckanderson67.00 Fritzer944.50 |
12-25-2018, 11:14 AM | #20 | ||
Rep 193
Lol what? Have you ever used a vacuum? |
12-25-2018, 12:20 PM | #21 | |
Rep 6,290
To confirm your work just look inside with a camera. You can get bore-scope cameras that won't break the bank. But as I see from other replies, I didn't realize just sracthing the cyl a bit can cause terrible issues. |
12-25-2018, 03:47 PM | #22 |
Rep 18,733
Noooo never. Genius.
