power steering whine
12-24-2018, 07:05 AM | #1 |
Rep 15
hi guys,
so I've had my car for about 6 months now, e92 325i m sport lci. I've noticed recently a whine when turning the steering, and it doesn't occur for the first quarter turn of the wheel. Now me being a complete amateur (and my last car being a 1.25l fiesta) presumed it was the power steering fluid running low, I have now come to figure out, that it has electric steering, as I could not locate a reservoir. I'm aware I sound like a complete novice but can anyone advise if I am correct in my assumption, and what they suspect the cause may be. as I have no idea if this will need to be an immediate or even an expensive fix. thanks in advance and happy xmas |
12-24-2018, 09:11 AM | #2 | |
Rep 141
Ultimately, this silenced my steering whine a lot. Just make sure to use whatever fluid your cap says to use. |
12-24-2018, 09:18 AM | #3 | ||
Rep 15
NathanK2433.00 |
12-26-2018, 08:31 AM | #4 | |||
Rep 15
12-26-2018, 09:07 AM | #5 |
Rep 328
Drives: 2013 335i, ‘08 328i, ‘03 316ti
It really looks like there is no hydraulic power steering and the associated reservoir in your car. Some of the f30 owners with electric power steering have experienced problems with the bolts holding the power steering unit in place. I don't know if that would generate the noise you have heard but I would take it to a sho specializing in BMWs to diagnose this.
12-26-2018, 09:11 AM | #6 | ||||
Rep 141
12-26-2018, 09:49 AM | #7 | |||||
Rep 15
12-26-2018, 03:23 PM | #8 |
Robot
1685
Rep 2,190
He's from London. 325i LCI means he has a N53B30 engine.. Naturally aspirated with direct injection!
Electric power steering was also available in the European market on these cars, so that would be my guess why there's no reservoir. Your whine is likely caused by something else - alternator or AC compressor. |
12-26-2018, 03:37 PM | #9 | |
Rep 141
12-27-2018, 04:56 AM | #10 | |
Rep 15
12-27-2018, 05:30 AM | #11 |
Rep 15
so I have localised the noise to just behind the steering wheel, noise is definitely coming from there and not anywhere in the engine bay, is sounds a little like when you slide something along a rubber grommet
12-27-2018, 08:22 AM | #12 | |
E46 Fanatic
42
Rep 152
S217A Active steering http://www.realoem.com/bmw/enUS/show...diagId=32_1571 So, you should be able to see if this option is present on your LCI E92 using an online VIN decoder. |
12-27-2018, 12:46 PM | #13 | |
ziddak
17
Rep 38
NathanK2433.00 |
12-27-2018, 01:21 PM | #14 | ||
Robot
1685
Rep 2,190
https://www.e90post.com/forums/showthread.php?t=635473 |
12-30-2018, 10:10 AM | #15 |
Rep 15
Thanks for the help everyone, spent some time on it today and found it was the rubber grommet as I suspected around the steering column where it passes through the firewall
