Starter installed
12-22-2018, 11:15 AM | #1 |
Rep 45
Drives: 2008 BMW M3
Starter installed
Well, just reached 156,xxx miles on my wife's 330i, has been a good daily! Battery died yesterday, installed a new one, then won't start. Troubleshoot down to the starter, bought it and installed. While reassembling noticed pvc valve hose to oil separator was broken. No wonder I couldn't figure out why that small oil leak, randomly appeared in my garage. Now waiting for hose to come in to finish the job...hopefully before Christmas!
12-22-2018, 02:52 PM | #3 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
https://www.e90post.com/forums/showt...5#post16941382 Last edited by mweisdorfer; 12-22-2018 at 02:59 PM.. |
12-22-2018, 03:54 PM | #4 |
Rep 2,108
If the sockets are long that may not fit still. I had similar flex head wrench and didn't fit with the socket attached. A box E-torx wrench is better and sure bet to use there, like this one which is what I used:
https://www.amazon.com/Vim-Tools-WTC.../dp/B000FN6PGA |
12-22-2018, 04:09 PM | #5 | |
Rep 2,108
If you have N52 with a silver engine vanity cover, those have another breather line that goes down to oil pan that may break too, which buying a spare of that line is also a good idea. Disconnecting that from the oil pan line without breaking is a challenge. I have been using 1/2 inch quick disconnect tool from this set, it works. I drilled a small hole on the flange of the 1/2 inch tool, tied a small wire (or thread ) to it, so if it fell down I could fish it out easily. Which it did fell down a few times. It is tight space, that is the difficulty of it. https://www.autozone.com/test-scan-a...l-set/2356_0_0 Also do not try to separate the electrical junction box from the intake manifold as some DIYs say. It is not meant to be separated, it is there with barbed tabs that won't come out. There are two small bolts on each end of the metal bracket this junction box is attached too. These small bolts screw on to the intake manifold. Undo those and let that junction box stay down together with the bracket. The bolts are torx. Most bolts are torx. It is a good idea to get a set of intake manifold gaskets, but may not be necessary if they are still pliable and stand up proud after removal. It is good to remove the throttle body assembly, it will give more room. The gasket on it is pretty robust silicon. By the book you need to replace, but not really necessary unless you find it compressed. |
12-22-2018, 06:09 PM | #6 | |
Rep 45
Drives: 2008 BMW M3
After all I end up spending $200 bucks between the remanufactured starter and the hose. Beats the hell out of $1,000 bucks the BMW steeler quote me! Car is back running fine now! |
12-22-2018, 06:19 PM | #7 | |
Rep 4,330
you need an angled wrench or flex head ratchet. I had no issues with a flex head ratchet and standard 3/8 socket. |
12-22-2018, 07:01 PM | #8 | |
Rep 2,108
And those VIM ones are recommended by a pro who couldn't fit his flex head in a you tube video he made specific for E90 N52 starter replacement which I had shared in another thread where you had again claimed that the flex head ratchet you had was fine. Your socket and the ratchet was fine, but that does mean everyone other flex head and socket combination will be fine. The one I had weren't, the pro guy who made the video had multiple ones only one old version was fine. That VIM e-torx set works fine. If someone wants more convenience GearWrench has ratcheting box E-torx wrench set too, still straight. These are handy for OFHG replacement too. |
12-22-2018, 07:13 PM | #9 |
Rep 2,108
Starter replacement video
Minute 22 he tries the flex head doesn't work, then goes into what worked and ends up recommending VIM box e-torx wrench that comes in the set I linked. |
12-23-2018, 08:06 AM | #10 |
Rep 45
Drives: 2008 BMW M3
I did have to buy an E-14 socket to remove the bolts holding the starter (once I removed the manifold). Removing the front bolt was easy with a 12" extension, now when I tried to set the socket over the rear longer bolt I couldn't sit the ratchet in place because there is hardly any room between the bolt head and the top of the transmission ( I believe is the tranny). I solved this issue using the closed end of a 11mm wrench and was able to undo this bolt without stripping its head, actually worked really well!
