PCV recall vs failing valve cover
12-21-2018, 08:56 AM | #1 |
Rep 220
Back in July I had the PCV heater replaced at the BMW dealer due to the recall . The SIB is # 11 16 17. Receipt sez "replace blow by heater (PCV heater elbow) 55215 WFGR". Now I have code problems popping up on the dash , P0050 (replaced 02 sensor) but code P2298 now appears. Local INDY sez code might be related to excess vacuum after he removed the oil cap with engine running. He also sez it points to the need to replace the valve cover due to the failing PCV.
QUESTION...while performing the PCV recall, did the tech remove the valve cover? If yes, could I claim PCV troubles are related to their work? Far fetched? Pls advise. Mikey P.S. Merry Christmas to y'all!! |
12-21-2018, 08:57 AM | #2 |
Hoonigan
6848
Rep 3,000
Drives: '09 328i, '98 Wrangler
No they wouldn't have touched the valve cover. The PCV heater is located under the intake manifold. On my 328i they removed the alternator (confirmed by the new alternator bolts) and replaced it that way.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
12-21-2018, 03:20 PM | #3 | |
Rep 4,330
find the bulletin for the PCV replacement and it will have the instructions. They don't do anything with the cover. |
12-22-2018, 10:45 PM | #5 |
Rep 386
Drives: 08 535xi 11 328xi
Just had my Valve cover replaced under the sulev warranty. It was making a high pitched squealing noise and excessive crankcase vacuum.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
12-23-2018, 12:47 AM | #6 |
Rep 2,476
I don't get how people think that because 6 months ago someone touched their car, anything else that goes wrong with it is somehow their fault. This is like the 3rd similar thread I've seen this week.
