BMW
X7 and XM
forum
BMW X7 (G07) Forums General BMW X7 Forum X7 towing discussion
      12-19-2018, 12:48 PM   #1
Eddy@ApexWheels
Eddy@ApexWheels's Avatar
442
Drives: E30 M3, F10 M5
The towing capacity has been stated as being 7500 pounds for the new X7 but I haven't seen tongue weights posted anywhere.
I have a new aluminum enclosed ATC trailer I want to tow but I'm concerned this is another SUV with wimpy tongue weight figures.
10-15% of a trailer's weight must be on the ball. That means 750 to 1125 pounds of tongue weight should be supported by the X7's towing capacity. If it's only 600 pounds or some other low number like the X5 then it doesn't even meet the minimum threshold required.
I have a weight distribution hitch I would install as well (which doesn't change the required tongue weight figure). Some vehicle systems/suspensions don't play nice with weight distribution hitches. Anyone know what BMW's official stance is for this vehicle?
      01-04-2019, 09:16 PM   #2
Eddy@ApexWheels
442
Is there an owner's manual posted yet where I can look this info up?
      01-04-2019, 09:32 PM   #3
squeaky
Drives: 330i
I tried to look up a manual for an X5 with air suspension when you first posted because I thought it would be comparable, but I didn't have any luck. I'll check the X5 forums again.
      01-28-2019, 08:04 PM   #4
SW19
SW19's Avatar
2453
Drives: 2016 Alpine White M2
Does anyone know which towing hitch design the X7 will have.
The BMW UK site says it is hidden when not in use but they show two different designs.
The US and Canada build your own websites also show a different design.
The first two pics are from the BMW UK site and the last two are from the Canadian and US build your own websites.
The final pic is what it looks like without the tow hitch.
Are any of these pictures the correct design.
      01-29-2019, 10:19 AM   #5
bjcarls
Drives: 22 Tahoe, 22 R1S, 23 Z07
I would guess the USA X7 has the standard box receiver, not the hidden j bar. Per tongue weight, the GLS has a 900lb tongue weight so maybe you'll get close.
      01-29-2019, 11:43 AM   #6
SW19
SW19's Avatar
2453
In the description for the tow hitch on the BMW Canada website it shows the same picture as the one on the UK website.I guess we won’t know for sure until the X7’s start arriving at dealerships.
      01-29-2019, 03:22 PM   #7
bagekko
bagekko's Avatar
Drives: Lots of BMWs
2018 M4 Vert  [0.00]
2006 Z4M Roadster  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
2021 X7 40i MSport  [0.00]
I highly doubt the $600 option is a hidden electronically adjustable tow hitch with stabilization monitor. That does sound cool and I am absolutely getting the hitch when we move into the X7. Whats in those cool pics is probably a $1500 option that will be available on year 2...... when they also announce the X7 can have the 50d LMAO.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX
2021 X7 40i MSport, 2006 Z4M 6spd
      01-30-2019, 02:25 PM   #8
Eddy@ApexWheels
442
I've been informed through a friend that the tongue weight will be 606 lbs. which is way less then I was hoping to see for a car that claims to tow 7500 lbs total. That is only 8% of the weight on the tongue which is less than what's recommended by any trailer manufacturer I've ever come across, or any distributor that specializes in trailers/towing.
      08-08-2019, 05:30 PM   #9
CruiseControl
Drives: 2020 BMW X7 40iM
I was told by a dealer that the BMW USA trailer hitch can be installed if the need arises after you purchase a build without one. Anyone have any experience with this, perhaps on an x5?
      08-09-2019, 05:47 AM   #10
jmciver
///M SubDriver
jmciver's Avatar
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
Out of curiosity, how much did they quote you? I priced out the parts individually and it came to $800+, and that did not include the body work/paint nor the vehicle coding. Also, did they confirm if the X7 comes pre-wired from the factory?
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      08-09-2019, 07:11 AM   #11
CruiseControl
I did not take it that far yet. My goal is to find a vehicle with a trailer hitch.
      08-09-2019, 05:19 PM   #12
FishOuttaWater
Drives: '19 X7 40i/'20 F-350/21 Jeep
How big is your trailer? I have an 18+2 x 102" wide V-nose ATC enclosed trailer. It weighs 3300# empty. I don't know what the tongue weight is but figuring the basic formula it will be between 450-500 lbs empty. I have an '18 F-350 SRW diesel I tow with but, not trying to be a Debbie Downer, it would be a real challenge to tow this trailer with my wife's X-7, if it were so equipped. First there's the width. I have the telescoping tow mirrors on my truck and while I can see fine it would be a challenge without them. Another thing you will need is a trailer brake controller. Probably need a WDH to throw some weight back on the front of the tow vehicle. Last, but not least ,my trailer is a little over 7'hi inside. There is a lot of drag, especially at highway speeds. Good luck and let us know how it does.
      08-09-2019, 07:05 PM   #13
CruiseControl
I don't own a trailer but have a bike rack that I spent good money on and use often.
      08-10-2019, 10:24 AM   #14
jmciver
///M SubDriver
jmciver's Avatar
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
+1. I think your rig, fully loaded with a car (I am assuming), tools, wheels, etc. might be a bit much for the X7 to tow safely and efficiently too. My rig comes in at a very conservative 6000 lbs fully loaded (it also has a tire rack now on it - not pictured) and I would feel very comfortable towing my rig with the X7. My open car trailer is a bit small at 18 ft (15 ft deck) and I use a WDH as well. My current tow vehicle is a 2007 Ford Expedition EL with a higher towing capacity, but less powerful engine than the 40i. Not sure if the extended side mirrors would be necessary with an open trailer setup like mine. I don't need them with my Expedition, but the Expedition is a bit wider than the X7.
[IMG]https://lh3.googleusercontent.com/1h...=w1156-h400-no[/IMG]
      08-18-2019, 09:02 PM   #15
Kotkot
Drives: M4
I tow 6000lbs+ 24 foot boat with 2019 X5 with air suspension and it’s doing just fine. Getting factory hitch is no brainer.
      08-24-2019, 02:58 PM   #16
Wild Blue
Wild Blue's Avatar
Drives: 2021 X7 M50i, 2004 330i w/ZHP
I'm not sure why this is anything new, unless the Australian hitch has been restricted to now, but apparently "3.5 ton towing capacity" now possible in Australia.
https://www.bmwblog.com/2019/08/22/b...-in-australia/
      09-20-2023, 11:56 AM   #17
avraham
Drives: 740i 2022 x7 40i 20245
Is anyone know more about self parking RV with the trailer assist on x7 2024
      09-27-2023, 08:14 PM   #18
Akira71
Drives: BMW M4 Competition, x7 m50i
UHaul installed my hitch, am I screwed?
So I am having a last-minute move to Florida and need to tow a 6x12 UHaul. I have a 2022 BMW X7 m50.
They said they would install the hitch on the car, and did, but it is not the factory option. I didn't even think of it.
How bad is this?
1. I don't seem to have a trailer mode option at all
2. Will this prevent me from towing?
3. I am going to be well under the gross weight max weight of the box trailer which is 4400 lbs.
I have not really found an answer or seen if anywhere where someone has done this and what happened.
Thank you in advance for any help or advice.
      09-28-2023, 04:08 PM   #19
sharp
Drives: 2021 BMW X7 40i
How bad is this?
1. Trailer mode has to be coded. You'll need to find a knowledgeable shop that can do that if you really want it.
2. No, the missing trailer mode won't prevent you from towing. But has the wiring harness been installed? It adds a 7 pin outlet so your trailer's lights and brakes work?
3. You'll need to dig into specs to make sure you don't overload your hitch, the rear axle and the car in general. If everything is within spec, then you're good.
UPD: Refer to this thread for more information https://g07.bimmerpost.com/forums/sh....php?t=1833185
      09-28-2023, 06:32 PM   #20
Akira71
Thank you! This was the info I needed.
1. If it is not needed I won't push for it, but I will check around in case.
2. Yes all the wiring is there and it was tested good.
3. The hitch system was also tested and is good to go for my needs. It is better than what my max is rated for the vehicle and I am towing.
Again, I really appreciate your response and the link!
      10-05-2023, 07:56 AM   #21
jrgrant
Drives: BMW X7, Ford F-150 King Ranch
Found out that the presence of a factory hitch means you lose the "kick to open" tailgate feature. So sad, but life is about choices, no?
      10-05-2023, 10:42 AM   #22
Phasers
Drives: 2024 X7 40i, 2024 X5 50e
I never use this feature anyways
xbimmers
