Left adaptive headlight stuck all the way to the left.
12-18-2018, 10:22 PM | #1 |
Rep 28
Hello guys, so as the tittle reads my left adaptive headlight on my 08 335i is stuck looking all the way to the left, I have the adaptive headlight malfunction warning in the dash so I'm guessing either the stepper motor has gone bad or the adaptive headlight module. this happend when I didn't seal the headlight properly after changing the bulbs and water got in it after I washed the car. I really don't care about the adaptive headlight feature, so is there anyway to get the light manually looking straight w/o replacing, coding parts?
12-18-2018, 11:00 PM | #2 | |
Rep 1,912
AandSC34.00 |
12-19-2018, 05:31 AM | #3 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
If you can't fix it through Ista, I'd say you'll either have to code AHL out and manually adjust it, or buy a new and or used one on-line and get it coded to your car. New new AHL headlight is about $700-850.00 depending on where you get it. Used probably a fraction of that price. |
12-19-2018, 09:03 AM | #4 | |
Rep 1,912
12-19-2018, 11:58 AM | #5 | ||
Rep 28
12-19-2018, 03:47 PM | #6 | ||
Rep 28
12-19-2018, 06:41 PM | #7 | |||
Rep 6,968
If it is, you will need the bmw tools software and a very good k & d cable from beemer geeks to fix it once you get a new/ used AHL module, if that's the issue. Of course you will need at the very least a 30amp battery charger or you risk bricking your car. |
12-19-2018, 06:54 PM | #8 | ||||
Rep 28
12-19-2018, 06:57 PM | #9 |
Rep 4,330
the stepper motor is replaceable by itself.
IIRC they are the same left/right, so you could swap them and verify that the fault follows the motor. check realoem with your vin for the part numbers. |
12-19-2018, 07:08 PM | #10 |
Rep 69
Realoem doesn’t show the horizontal stepper motor for the pre-LCI E92s. At least I couldn’t find it. The couple threads I read said only the vertical stepper is replaceable. I have an intermittent fault on my passenger horizontal stepper motor and would love to be able to replace it.
2009 335i Coupe M-Sport MT 136,000 miles
2013 Mini JCW 16,000 miles 2000 Lexus LS400 82,000 miles |
12-19-2018, 07:17 PM | #11 |
Rep 4,330
that's my fail.
I didn't read closely enough. no, I don't believe the horizontal ones are replaceable. I also don't think there's enough adjustment in the manual adjust to get it aimed correctly again. I currently have my passenger side adjust broken, so I'll be opening it up soon enough and finding out. |
12-19-2018, 07:52 PM | #12 |
Rep 6,968
Give the guys at FCP Euro a call. They will give you a lifetime warranty on the parts you buy.
12-19-2018, 08:25 PM | #14 |
Rep 13,103
One of the common problems reported here for those
is the control arm pops out of the ball joint. Sometimes you can pop it back in according to past posts. |
