Horn is missing after removing airbag
12-17-2018, 02:55 PM | #1 |
Rep 92
hey there. horn seems to be missing. I replaced the wires, as old ones definitely looked snapped, but that did not help. The main problem is that I can not find where horn wire should be plugged on. it's on 335xi lci.
12-17-2018, 03:30 PM | #2 |
Run Deep
15127
Rep 4,123
Drives: Back and Forth To Work
Garage List 2018 Alfa Romeo Giu ... [0.00]
2022 Ford Bronco 2d ... [0.00] 2016 Alfa Romeo 4C [8.50] 2019 BMW i8 Roadster [0.00] |
Hopefully this should help. Photo below of where it goes, plus link with full photo DIY on removing and reinstalling an E9X wheel. Should do if for you, I would imagine.
https://www.e90post.com/forums/showthread.php?t=11825
Don't sweat petty things....or pet sweaty things.
12-17-2018, 11:59 PM | #3 | |
Rep 92
12-18-2018, 07:41 AM | #4 | |
Run Deep
15127
Rep 4,123
Are you referring to the grounding wire that I have circled in PHOTO 2? If yes, then it attaches to a screw noted in PHOTO 1. Your wheel seems slightly different and I don't see that grounding screw in your photo. I would believe, that even if you don't have that, you can attach it to anything that is grounded. This might be your problem, as if the horn isn't grounded then it isn't going to work.
12-18-2018, 08:24 AM | #5 | |
Rep 92
12-18-2018, 08:38 AM | #6 | |
Run Deep
15127
Rep 4,123
If yes - that is also a grounding wire, I believe. In my photo, it just slides over a small metal tab protruding from the metal center plate of the steering wheel. In your photo, it appears to be missing. If that is the case, I would imagine that you can attach it to any piece of protruding metal on that plate you can find. Your metal plate looks odd - it might be due to your location as compared to mine, but who knows. If unable to find anything to secure it too, you could always solder it to the plate as a last resort. I would think that might work, although I would try to find a better solution first.
Pupsaiden44.50 |
12-18-2018, 08:53 AM | #7 | |
Rep 92
12-18-2018, 09:01 AM | #8 |
Run Deep
15127
Rep 4,123
Cool, man. Hope this helps also - see below. Pic one is it attached and pic two shows what the tab looks like with it removed.
Pupsaiden44.50 |
12-18-2018, 09:18 AM | #9 |
Rep 92
Run Silent15127.00 |
12-18-2018, 11:42 AM | #10 | |
Rep 92
12-18-2018, 12:24 PM | #11 |
Run Deep
15127
Rep 4,123
Fantastic! Always great to hear of a positive outcome!
TheMidnightNarwhal2657.00 |
03-25-2019, 03:15 PM | #12 |
Rep 787
Well, my horn doesn't work, so this is what I'm going to check!
