N55 engine seized
12-16-2018, 08:07 PM | #1 |
Rep 29
N55 engine seized
So 2 weeks ago I dropped my '11 e90 off at my independent mechanic for a leaking OFHG and a tune up including replacing all fluid, new plugs, and coil packs. I received a call a few days after dropping it off and he said that he had to replace the solenoids too. I was upset because they were fine when I dropped the car off. He agreed to give them to me at his cost ($200) and not charge me labor. I agreed.
I got a call from him last week saying the car was all set. He charged me just over $2k for the work. I was looking forward to the car running in top shape. I went and picked it up and the car started vibrating under roughly 50% plus throttle. It ended up going into limo mode and I got an engine malfunction warning. I turned the car off and called him. He asked me to bring it back to him. After waiting 10 mins, the warning went away and I drove it back to his shop and got a ride home. Here's where it gets interesting.... I received a call from him 2 days later. He said it was a bad coil pack. He replaced it and said the car was running perfectly. He said he was roughly 20 mins into his test drive and the car just shut off on him. He had it towed back to his shop and bottom line is the engine is seized and it needs a new engine. He said he took apart the top part of the engine and the issue is not there so it must be in the bottom part of the engine. Now I'm clearly no mechanic so Im not sure what he's talking about or if he's just BS'ing me. He asked for the weekend to think about how he should proceed. I told him he has insurance for this type of thing but he thinks that his insurance won't cover it b/c the seizure couldn't be caused by what he did and is claiming it was a complete coincidence which is total BS. The car was running perfectly before I dropped it off for preventative maintenance. Not CEL or anything. I hope he does the right thing and files an insurance claim but I spoke to my attorney on Friday in case he sticks with his "coincidence" story. Any advice or thoughts on this would be much appreciated. I'm racking my brain about what to do about it or how I should proceed. Hoping to get some opinions on what could have casued this from those much more knowledge then me too. Thanks for letting me vent! |
12-16-2018, 08:25 PM | #2 |
Rep 429
Drives: 2011 e92 335xi
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD Last edited by Supermoon; 12-16-2018 at 08:37 PM.. |
12-16-2018, 08:30 PM | #4 |
Rep 2,293
is this a BMW specialist shop or a do it all type of shop.
is he sure the engine seized? At this point I wouldn't trust anything he says , and I would personally get the car towed to a different BMW specialist shop to get a proper opinion As of right now , you are only going by what he tells you , so unless you get another shop involved to evaluated what could've happened , it will very hard to prove any wrong doing |
robthewrench266.00 |
12-16-2018, 08:45 PM | #5 |
Rep 29
Good point. I just found this out on Friday. This all happened while the car was in his possession so it seems cut and dry to me.
He works primarily on BMW's, Audi's, and Mercedes. I've been going to him for 2 years now and have been happy up until this point. Assuming he won't submit an insurance claim, I'm going to get my attorney involved and will discuss with him bringing it to another shop for a 2nd opinion. |
12-17-2018, 09:12 PM | #6 |
Rep 245
It's not unusual for an N55 to seize within a few dozen miles of an oil filter gasket replacement. The housing design makes it very easy to drop dirt or gasket crud into the oil passage during the repair and it seems there may be something special about the N55 crankshaft oil passages that make them much more susceptible to clogging than the countless other BMW engines with this same ofhg arrangement.
Tallicia73.50 |
12-17-2018, 09:19 PM | #7 |
Is it the shoes!?
3884
Rep 5,112
12-18-2018, 08:38 AM | #9 |
Rep 6,290
12-18-2018, 08:39 AM | #10 | |
Rep 6,290
12-18-2018, 09:10 AM | #11 |
Rep 1,753
12-18-2018, 09:15 AM | #12 |
Rep 6,290
12-18-2018, 09:19 AM | #13 | |
Rep 1,753
Does anyone know if the oil passage is different from N54 to N55 ? |
12-18-2018, 09:50 AM | #14 | |
Rep 2,026
A completely seized engine seems more like complete loss of oiling to me. Like, your mechanic forgot to put oil back in the car. Or, your mechanic pinched the gasket and your bearings got fed coolant. Or, your mechanic left a rag stuffed in the passage. This coming from someone who spun bearings in his N55... I did my oil filter housing gasket 3x on this engine and it never had an issue until I had a complete oiling failure on track. Review the N55 engine PDF if you want to see the oil rail and passages. Last edited by bbnks2; 12-18-2018 at 10:10 AM.. |
12-18-2018, 09:50 AM | #15 |
Rep 29
Quick update: I just heard back from the mechanic. He stepped up and filed an insurance claim. The adjuster will be there in 2 days. I'll keep everyone updated on the resolution.
12-18-2018, 09:54 AM | #16 | |
Rep 1,753
Tallicia73.50 |
12-18-2018, 09:55 AM | #17 |
Rep 1,753
12-18-2018, 09:58 AM | #18 |
Rep 29
12-18-2018, 10:22 AM | #19 |
Rep 2,026
No matter what it points to the mechanics work and not the engine itself. The only plausible explanation I see that would free the mechanic of this liability is if there is some inherent issue with the oil pump and air. Not likely as people crank rebuilt engines with 0 oil pressure without issue. People put completely empty oil coolers into their car and crank it right up without issue.
Tallicia73.50 |
12-18-2018, 10:25 AM | #20 | |
Rep 1,753
Tallicia73.50 |
12-18-2018, 10:28 AM | #21 |
Rep 2,026
12-18-2018, 10:30 AM | #22 |
Rep 1,753
