E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > voltage regulation
      12-16-2018, 04:46 PM   #1
tbuck92
Drives: 2008 328xi
voltage regulation
Hello,
I have a 2008 328xi that the battery doesn’t seem to be charging in. I have a video of the voltage at idle with no accessories running. The car has gone into limp mode once due to low voltage. An IBS Error code does come up when scanned but I’ve tried the car with it connected and disconnected and there is no difference. The alternator is relatively new but it is a rebuilt which i told myself was a bad idea. A lot of matainence has been done recently along with a new battery so I’m not sure if this is because of the alternator/voltage regulator. The advanced auto part guys tested the alternator and battery and they came up ok but who knows. If it’s the alternator I will put a new non rebuilt in. The voltage seems to be fluctuating quite a bit though at idle (IBS connected).
Video of voltage at idle:
      12-16-2018, 05:18 PM   #2
ctuna
Drives: 325xi 06 wagon MT
If you have a lead acid battery the alternator voltage should be above
14 volts around 14.5 average.
      12-16-2018, 05:44 PM   #3
tbuck92
Drives: 2008 328xi
It is an AGM battery.
      12-16-2018, 06:55 PM   #4
PhaseP
Drives: 325XI
Disconnect the small wire that goes to alternator, and try to see if you get steady voltage that way. Small wire is how the ECU controls the alternator voltage regulator to tell it what voltage is should set its output.
When disconnected alternator goes to default mode like a regular alternator, should have steady output about 14 V.
If with the small wire disconnected you still have the same fluctuations it is your alternator. The slip rings may not be making connection all the time on the brushes. A rebuilt one should have replaced both the slip rings and brushes but you would never know.
Another thing to try is to increase the RPM while in neutral, watch if the voltage gets steady at some RPM range. If this happens again it shows problem is in the slip rings and/or brushes.
If the voltage is steady with that small wire disconnected, problem is most probably outside of the alternator. It could still be the voltage regulator though. The Valeo alternator in my car is very easy to replace the voltage regulator with a new now. Don't know what you would have.
New voltage regulator comes with new brushes. But not new slip rings, that requires a rebuild.
e90post
