E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Clutch problem
      12-15-2018, 03:37 AM   #1
SjohanhE91
Drives: BMW E91 318i 2006
Clutch problem
Hi, I just installed a new clutch kit from Luk on my manual E91 318i, including master and slave cylinder. After installation the clutch is working but the clutch pedal will not go all the way to the floor as before I installed the new clutch. The pedal stops 1-2 inches higher than before with a stiff/spongy feel. Can It be the self adjusting pressure plate that has been installed incorrect?
      12-15-2018, 09:57 AM   #2
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Did you bleed the hydraulics properly?
      04-28-2019, 07:11 AM   #3
1fastt2
Drives: 335i
Curious if you ever got this straightened out?
e90post
