E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Sport Seat Retrofit
      12-13-2018, 06:54 PM   #1
Smith_Jason
Drives: 2013 X5 35d
Sport Seat Retrofit
I did a little searching on here but didn’t find (quickly) an answer.
My E91 came with regular leather seats. They are fully electric with memory and heat.
I assume that sport seats are compatible with mine without any additional wiring ? There are lumber and side bolsters I assume and do they need any additional wiring. If that’s the case I wouldn’t bother but if it’s strictly a bolt in and plug in affair I may do it.
For reference it’s an 09 so it would have to be LCI seats.
      12-13-2018, 07:08 PM   #2
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
Seat are the Bermuda triangle of retrofits. You will have to post pics of your seat harness pinout.
      12-13-2018, 07:29 PM   #3
smass
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
Since you have heated power seats now, there is a better than average chance you will be fine. When you add heat, you get a 2nd power and ground run to each seat plus the wiring needed to turn on the pass side heat.
      12-14-2018, 11:33 PM   #4
axe127
Drives: 2009 e91 328i xDrive 6MT
I swapped heated, electric (w/ memory), lumbar, non-sport seats for sport seats with the same exact options with no extra wiring needed. Everything works just fine. My car is an ‘09 E91, donor was an ‘11 E90.
Be aware that if the donor car was in an accident, you may need to swap the buckle/pre-tensioner assemblies from your old seats to the new ones or you’ll have an airbag light. The rubber boot under the buckle will be collapsed, or wrinkled, if that’s the case.
CSBM52721.00
wdb4732.00
      12-17-2018, 07:05 AM   #5
Smith_Jason
Drives: 2013 X5 35d
Good stuff. I figure it should be pretty straight forward if I decide to go ahead and do it. I have a beige interior so would need to find suitable donors. And I am in Canada so there’s that.
      12-17-2018, 10:08 AM   #6
triax37
Drives: 2017 F31, 2014 F15, 2002 M3
I did this swap in a 2007 E91. I don't think there is a major change from Pre-LCI to LCI seats, but the headrests are different - I think in 2009 they started using "Active Head Rests." So as long as you stick to 2009-2012, and are swapping seats with the same options (power, heat, etc.), you should be in good shape.
https://www.e90post.com/forums/showthread.php?t=784905
      12-17-2018, 01:23 PM   #7
Fritzer
No one sleep in Tokyo
Fritzer's Avatar
Drives: 2011 E90 328i//1995 E34 530i
I believe even E90s with manual seats optioned have the wiring routed to accommodate any of the other seat functions that could have been ordered from the factory. Anything OEM should work fine with no issue.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
e90post
