E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Overheating issues
      12-12-2018, 12:50 AM   #1
NFiftyWon
Drives: E90 LCI 328 X-Drive
Overheating issues
Hi all,
Today my e90 n51 LCI decided to give me a high temp indicator and severely limit my speed while going down the interstate. I pulled over and inspected the engine bay.
The radiator and the fan were definitely working. It was blowing a respectable amount of cold air, enough so that when i tried to turn on the heat in the cabin to help expel some heat it only blew cold air. My coolant was low but there was still some in there. I topped it off, reset the computer and started to drive again. Instantly the fan kicked on full force. The engine bay didnt appear to be very hot. The cap caps came off with a little pressure but no immense heat. Just trying to get an idea of what could be the cause of this as i have not really run into heat issues with cars before. Any info would be of help.
      12-12-2018, 07:01 AM   #2
robthewrench
Drives: 11 E90 335i
Waterpump. No heat in the cabin is a big clue. The engine is hot, but no hot coolant is circulating. You also said no heat in the radiator, so again hot coolant is not getting circulated.
bone stock
      12-12-2018, 07:25 AM   #3
Bavarian Tech
Bavarian Tech's Avatar
267
Drives: 335i
2006 330i  [10.00]
More than likely, your water pump is begging to fail.
      12-12-2018, 08:32 AM   #4
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
We cannot say it enough... scan the car with a BMW scan tool. It's most likely the pump. A scan will confirm. Look for 2E81/2E82 codes.
      12-13-2018, 08:06 AM   #5
E82Derek
Enthusiast
E82Derek's Avatar
Drives: 2008 BMW 135i E82 Coupe (N54)
Sounds like a water pump fail. Like Efthreeoh said, scan the car and see what codes it throws
e90post
