car feels floaty on highway
12-10-2018, 08:09 PM | #2 |
Resident Pedant
503
Rep 792
Make sure your tire pressure is correct.
Is your car standard or sport suspension? How many miles on the shocks now? I had 70k miles on my standard suspension and the car felt "floaty". I went whole hog and upgraded to the BMW Performance Suspension (springs, struts, and shocks). Definitely no float now.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
12-11-2018, 05:23 AM | #4 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
12-11-2018, 05:43 AM | #5 | ||
Rep 2,243
Drives: 2007 328i / 2014 M235i
12-11-2018, 07:49 AM | #7 |
Rep 6,968
12-11-2018, 07:50 AM | #9 |
Rep 77
12-11-2018, 08:15 AM | #10 | |
Rep 6,968
You'll need: 1) strut bearings 2) bump stops for the front 3) spring mounts for the front 4) upper, upper shock mounts (rear) 5) bump stops (rear) 6) upper lower shock mounts (rear) 7) lower, lower shock mounts (rear) 8) spring mounts (upper & lower) This is a basic list; there's probably something I forgot. BMWfans is your friend 😉. Use this website to look up exact part numbers and make a list. If you are in south Florida, the heat & humidity is a b@itch on anything made of rubber on your car. Don't hesitate on changing out parts made out of rubber, which are supporting hardware for suspension of the car. In about 25,000 - 35,000 miles or so, I'd be changing out front control arms, rear control arms & bushings in the rear subframe proactively. FCP Euro will give you a lifetime warranty on all of your parts. |
catcher22294.00 Antetokounmpo1551.50 |
12-11-2018, 01:18 PM | #12 | |
Resident Pedant
503
Rep 792
https://www.ecstuning.com/b-genuine-...AaAjyHEALw_wcB
12-11-2018, 01:33 PM | #13 |
Rep 1,815
Ok, I hunted for years on how to improve the feel of my E87 118I. I did the complete suspension and still it felt floaty and nervous on the road. I recently coded it for the M-sport suspension and now it is the way I always wanted it to feel. The set you bought above will make a huge difference but it will never have the true solid feel until you find a coder and code the M-Sport suspension retrofit via ista-p.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
12-11-2018, 01:54 PM | #14 | |
Rep 418
12-11-2018, 02:13 PM | #15 |
Rep 1,815
The coding (from memory) adjusts dtc, DSC, and steering as far as I know. I think it was one of the single best mods I have ever done to the car.
12-11-2018, 02:27 PM | #16 | |
Rep 6,968
Please list what you have on your car.. |
12-11-2018, 03:19 PM | #17 |
Rep 418
12-11-2018, 03:40 PM | #18 |
Hoonigan
6848
Rep 3,000
Drives: '09 328i, '98 Wrangler
Unless you rally race the car I doubt the suspension is worn out enough at 90k miles to feel floaty.
What kind/size of tires are you running? I bought my 328i with 8 year old run flats and they were horrible. I could feel the back end getting floaty at certain speeds. I replaced those tires with snow tires (which are soft and squishy) and the difference is night and day. I'm sure in the summer when I put on performance tires it will be even better.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
12-11-2018, 03:45 PM | #19 | |
Rep 6,968
12-11-2018, 03:46 PM | #20 | |
Rep 6,968
Please list what you have on your car? |
12-12-2018, 03:30 AM | #21 |
Rep 1,815
My e90 335i has the BMW performance suspension and my e87 has the performance springs with Bilstein b8's
12-12-2018, 09:19 PM | #22 | |
Rep 1,322
