Airbag resister - what am I doing wrong?
12-09-2018, 12:57 PM | #1 |
Rep 996
12-09-2018, 05:59 PM | #4 |
Rep 1,023
I'm honestly not sure whether or not using the good ol' resistor fix will work in these cars, but I imagine it would. Like most cars, all the computer looks for is a resistance drop across the airbag. However, as pointed out above, those aren't resistors, they are fuses, which have about 0 resistance. You may have actually blown a fuse shorting the circuit like that, but again, I'm not savvy on these systems.
If resistors will work, you will need to research the correct resistance to replace the airbag with, and create that out of available resistors. I did the same thing in a Miata that I put an aftermarket steering wheel in, and it worked perfectly.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
12-10-2018, 02:01 PM | #5 | |
Rep 525
OP, do you have a JB4? it can clear airbag codes. So can BMW software. Airbag codes will no auto-clear. Clear them with code-clearing tools and let us know if the codes come back. |
12-10-2018, 03:22 PM | #6 |
Rep 996
Thanks guys! Noob mistake. I think the Momo kit only came with fuses, no resisters.
Ordered some 3.3ohm 0.25watt metal film resisters on eBay for $5. Will report back once I try those out. I have a foxwell nt520 which should be able to clear airbag codes. |
12-10-2018, 05:06 PM | #7 |
Rep 4,330
there are wound resistors under that heat shrink.
put an ohm meter on them. if they came with the momo kit, and were for this application, call momo and ask them why it doesn't work. |
12-10-2018, 06:41 PM | #8 |
Rep 996
Thanks - didn’t notice those. I think the Momo resisters are 2.0 from my research. I believe bmw’s need 3.3 so going to test out the bay ones.
12-10-2018, 08:55 PM | #9 |
Save the manuals!
6015
Rep 6,746
Just code it out... so much easier than hacking up the wiring with ghetto fixes.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
12-11-2018, 01:20 PM | #11 |
Rep 996
12-12-2018, 07:19 PM | #15 |
Save the manuals!
6015
Rep 6,746
This could've all been avoided with a 5 minute coding job, lmao. By refusing to put a little effort and invest in a laptop with a BMW diagnostics/coding suite, you've now dealt with even more work and headaches and are still no closer to resolving your issue The least you could've done is look up the wiring diagram to see what wires are doing what, instead of random fuse/resistor combinations.
Good luck. edit: And you're in Chicago, there's several BMW coders out there. Sheesh.
12-12-2018, 10:03 PM | #16 | |
Rep 996
