Brake fail HELP
12-08-2018, 02:48 PM | #1 |
Rep 5
Brake fail HELP
I have a 328i e90 with braking issues. Okay as I was getting off the freeway I was braking pretty hard then I turned off the dsc to "drift" a little since it was raining. Right after that my brake pedal stiffened up, so I have to apply tons of pressure to get the vehicle to stop. No lights are on as I have read on some threads that a faulty abs typically turns on brake, abs, and dsc lights. Not sure it may be the abs pump and not the abs 'computer'? Just changed the brake pads and had cleaned the calipers before the incident. I did the "booster test" which was pumping the brake pedal while the car is off, then while still pressing the brake pedal it should sink once i turned on car. the pedal is stiff at all times I'm going to bleed the brake line to see if that does it. Any info would be great, thanks in advance!
12-08-2018, 02:50 PM | #2 |
Rep 18,733
Sounds like there is no vacuum in the brake booster.
12-08-2018, 03:01 PM | #4 |
Rep 18,733
I don't know what engine you have. The N52 uses a vacuum pump to create vacuum because the valvetronic system doesn't create manifold vacuum. I'd hook up a mechanics vacuum to the booster and see if the pedal feels normal.
12-08-2018, 03:14 PM | #5 |
Rep 5
It's an N51. Thanks again for your input
12-08-2018, 03:43 PM | #6 |
Rep 2,526
Drives: 2011 328i Wagon
No difference for this purpose.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
12-08-2018, 06:09 PM | #7 |
Rep 18,733
The N51 has a vacuum pump.
