E93 daten for INPA
12-08-2018, 09:54 AM | #1 |
Rep 2
E93 daten for INPA
Can anyone help please as need the correct daten for e93 (Nov 2008)? Also the correct INPA to use it? Having problems setting it all up...
12-08-2018, 10:58 AM | #3 | |
Rep 4,031
Here are links to Site from which you can download INPA/ISTA, and get good K+DCAN cable: BMW-Specific Diagnostic Software, INPA (Standard Tools), ISTA (Rheingold): https://www.bimmergeeks.net/downloads BimmerGeeks Pro K+DCAN Cable: https://www.bimmergeeks.net/product-...eeks-pro-cable ALL E9x models (E90 thru E93) use E89 Daten files, so download & install E89 daten, but when you go to connect, select E90...E93. Any questions, post back. I also attach a pdf containing these & other links to E9x References. Of particular importance are TIS Online Service Manual & Bentley Manual. George |
12-08-2018, 11:26 AM | #4 | |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
12-08-2018, 12:17 PM | #5 | |
Rep 4,031
1) Connect to each of the ~ 20+ modules; 2) Use Functional Jobs in INPA to read Fault Codes in ALL modules; 3) See Information and Menus of functions in each module; 4) Read Fault Codes and Details & Freeze Frame Data in all modules; 5) See Parameters or all Status functions in each module; 6) See & perform Activations/Steuern in each module; 7) Connect to other series/models that use Daten files other than E89? What about using ISTA/Rheingold? Does the SAME apply as far as ALL functionality in ANY model WITHOUT Daten files being downloaded? E89 Daten files are 4.51 GB compressed RAR file and > 10GB unzipped, and that is just for one series of vehicles. How can the INPA shell possibly have ALL the necessary Data files to run INPA on ANY series of vehicles, or even just E9x vehicles? As installed on my computer (NOT Bimmergeeks download) the "INPA" folder in "EC-APPS" is only 179MB. If my concepts of how INPA is configured are incorrect, I would appreciate your taking a moment to enlighten me. Thanks, George |
Pladi718.00 |
12-08-2018, 01:39 PM | #6 | |
Sua Sponte
1299
Rep 2,850
The BG download is over 2.5 GBs unpacked and the vast majority of that is Ediabas. The Ediabas folder is the key here. That's where the vast majority of the files used by INPA and ISTA/D are stored. Remember, it's only doing diagnostics, calibrations, etc. there's no flashing or programming involved therefore their size is relatively small. It's how Carly and BG's ProTool can get away with using a phone to perform a lot of these functions, by using only the specific files they need to accomplish the menu of operations they choose to include in their app. For instance, BG only uses a 500mb download to perform all it's functions across the E6x, E7x, E8x, and E9x models it covers. Now look at the data folder inside your E89 datens folder, it's where all of that 10.5 GBs of files is stored. This is what's used for flashing and programming by WinKFP, consider it all the software that's been used since 2006. Loads for more info and complexity here because it contains all the various software versions of all the different modules that BMW has used since the inception of the E9x, E8x, and Z models. Not the most technical explanation but I think you get the gist. I have three different laptops with various programs I can use. My old XP has a old version of INPA that works extremely well with older E series, it has some calibrations and adaptions that got phased out in the newer versions. There's no daten loaded and it works perfectly.
12-10-2018, 07:52 AM | #7 |
E46 Fanatic
42
Rep 152
12-10-2018, 07:55 AM | #8 | |
Sua Sponte
1299
Rep 2,850
12-10-2018, 09:18 AM | #9 |
Rep 7,215
When following the Bimmergeeks isntallation, skip the step where it says to delete the folders in the C: drive, and just copy the others overtop. All of the files are pretty much there except the ones needed for flashing - no daten files required. you can even use NCSexpert.
12-10-2018, 10:09 AM | #10 | |
Rep 4,031
From the help offered so far, do I correctly understand: 1) That there ARE Daten files INPA uses to connect to the ~ 20+ modules in each series of cars, as well as to communicate with those modules? 2) That the Daten files INPA uses to perform its functions are a very small subset or selection from the ENTIRE E89 (for E9x purposes) Daten files (which unpacked has a total size of ~ 10.6GB)? 3) You say the Daten files are "pre-installed" within the folders. At what stage of downloading & installing the INPA/E89 Daten Folders/ Files, are the Data files installed in the Folders used by INPA? 4) When I installed BMW Standard Tools/ INPA a year ago, as I recall the procedure now, I downloaded two different groups of folders/files: (1) Standard Tools, and (2) E89 Daten. Those folders/ files were then unzipped and transferred to my laptop. In running the Install process, selected files from the large (10.6GB) E89 Daten Folder were installed into, or tagged for use by, the INPA program (located in EC-APPS). Is THIS the "pre-installed" process that you are referring to, and WHERE are the files/ folders actually installed (in what folder)? EDIABAS?? EDIABAS\ECU??? 5) I think I understand you to say that at some point the INPA program has to either copy or tag certain files from E89 Daten for use when running INPA. Further I think I understand you to say that the majority of E89 Daten files are NOT used by INPA, and if one is NOT using WinKFP for flashing and programming, then there is no need to retain the bulk of the E89 Daten files on the laptop hard-drive. If those concepts are correct, how can one identify the folders/files which may be deleted without affecting/ reducing INPA functionality? 6) Is it more correct to say that at some point INPA installation had to "Install" (copy or tag) selected files from E89 Daten, and once that is done, the E89 Folder (10.6GB) may be deleted? 7) In other words, where has the Install Procedure put/saved the Data files INPA needs to connect/ diagnose/ control E9x modules (folders/files that we do NOT want to delete), and what folders used in the Install Procedure may now be safely deleted as duplicative? I apologize if my "conceptions" are actually "mis-conceptions" -- any help in pointing me straight would be appreciated. Thanks, George |
12-10-2018, 02:00 PM | #11 | |
Sua Sponte
1299
Rep 2,850
EC-APPS-> INPA-> SGDAT-> IPO files EDIABAS->ECU->PRG files E89 folder contains SGDAT, ECU, plus daten and data which is why in older versions you needed to download E89 datens and upload to fill the folders to run INPA, etc. No longer necessary if you just want to use INPA, NCS Expert or Tool32, BUT you must use a software pkg that includes SGDAT and ECU. So it basically boils down what pkg you use, what's included outright, and will you be flashing and programming with WinKFP.
12-10-2018, 04:00 PM | #12 | |
Rep 4,031
I do plan on installing BG version sometime this winter. BTW, have you found any glaring errors in German>English translation in BG version (like Print for Pressure, or Worse)? I assume Menus have been translated to English? What about Fault Code Definitions or other data readout -- is that still (mostly) in German requiring translation, or is BG version nearly ALL English? Thanks again, George |
12-10-2018, 11:53 PM | #14 |
Rep 2,806
I know wrong forum, but, this discussion is very pertinent to me now. I have the BG Std Tools installed and have used it successfully to do some simple coding. I want to use NCS Dummy to disassemble and reassemble my FRM module (trying to change blinker count).
Do I need the full E89 Daten file? If so, does it get used properly being a separate folder on "C" drive?
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
12-11-2018, 02:09 AM | #15 |
Rep 13,103
All these versions of Inpa come with some daten already files installed.
the ilevel of the car tells you which set of daten files you are currently using and there is a cross table for relating the ilevel to the daten level described on the coding subform. If you load ista and do a full id on your car it will display the ilevel at the time the car was built and what it is now. Most people don't need the latest I level to do basic coding or diagnostics on there car. https://www.e90post.com/forums/showp...48&postcount=2 |
12-11-2018, 07:13 AM | #16 | |
Sua Sponte
1299
Rep 2,850
I get why most people like to use INPA, it installs easily, loads quickly, relatively intuitive, and performs quite a few useful functions. ISTA/D blows it away. Yes I know, some have a hard time installing it, understanding how to use it, doesn't load as quickly, etc. but if you're going to spend more than a couple minutes at a time with INPA or really need to get into diagnostics, adaptions, and general platform knowledge it's the only way to go, and it's completely English.
12-11-2018, 07:55 AM | #17 | |
Sua Sponte
1299
Rep 2,850
You'll start with the disassembly tab, Daten file for disassembly, browse (takes you straight to NCSEXPER\DATEN), click on your correct FRM file, Open, now save the disassembled file to your desktop. Now open it on your desktop, if it asks you to pick a program, use Notepad and make it the default for the future. Now under the Edit tab, use find and search for MIND_ANZ_ZYKL_TIPP_BLK, 1, 2, 3 (four parameters all together) PARZUWEISUNG_PSW1 : 0007 (01) // wert_01 PARZUWEISUNG_PSW1 : 002F (03) // wert_02 This is what you're looking for, wert_01 represents the single blink, indicated by the 01 in parentheses, wert_02 is the triple blink (03). You can change either one to whatever blink # you want (up to 7 I believe) do this with all four parameters, just remember to use the correct option in Idrive settings or BC to access the new blink option. Now with the daten modified, using the file tab, use Save As, hit Save, you'll get a pop up, this file already exists, do you want to replace, hit yes. You can go back to the file on your desktop now and check it to make sure the changes you made are there if you wish. Back to Dummy, under Disassembled file for assembly, browse, navigate to that file you just made on your desktop, click on it, Open, double click on E89, Save, and confirm Save , yes. If you want to confirm you can just open Dummy, load that FRM module, navigate to those parameters and check your wert values.
gjm1202183.00 |
12-11-2018, 08:49 AM | #18 | |
Rep 2,806
Many thanks. What you described is what I've been learning to do on an unconnected computer so as not to make a mess. Thanks to your post and help from Sensible on a thread I started in the Coding sub-forum I think I'm ready to do this job. What scared me is that this is a little step beyond simple coding which I see as more of toggling features on & off. It seems like an in between coding and programming. (I guess the battery coding I've done counters that argument since you enter specific values.) Is it correct to say if one never uses WinkFP the huge Daten files are never called on by the programs & are completely redundant?
12-11-2018, 09:15 AM | #19 |
Rep 7,215
NCSexpert is only coding. Not programming. That's what WinKFP does.
You don't even *really* need all of the files for WinKFP. You just need the specific files for your car (I use expert mode though). |
12-11-2018, 09:20 AM | #20 | ||
Sua Sponte
1299
Rep 2,850
If you're using a software pkg that already has C:\NCSEXPER\DATEN\ filled without having to download and upload the daten separately then there's no need to do so. Everything will function outside of WinKFP.
gjm1202183.00 |
12-11-2018, 09:33 AM | #21 | |
Rep 2,806
12-11-2018, 10:13 PM | #22 | |
Rep 2,806
I was using the Manipulation profile in the Bimmergeeks NCSExpert tool. Could this have some effect?
