New Owner of a 335i e92! Have lots of questions, need help!
12-07-2018, 09:11 AM | #1 |
Rep 7
1. Passenger seat latch to get in to the rear seats isn't working properly.
2. Can someone send me good links to good undercarriage shields. 3. Any things I should know as a beginner when it comes to owning a BMW? I have 2009 335i e92. It has 90k miles. |
12-07-2018, 09:28 AM | #2 |
Rep 709
Get yourself a way to read fault codes, that is if you want to know what's going on with the car.
I myself have Bimmergerks Protool: More expensive, you can't do everything, easy to use Others use a cable and a laptop = Much cheaper, you can do everything, has a learning curve |
12-07-2018, 11:55 AM | #3 | |
Major nutz
86
Rep 1,488
Drives: '09 n54 e92xi, 6mt, kw v3
#2. I would simply google that. I recently saw that part at bmwpartshub.com/oem-parts #3. Do you have the history of your car? I bought my car new in 2009 and still have it! Seems like there aren't many of us left. My car has 103k miles now. Critical things I have done: Water pump (and thermostat) at about 50k miles. https://www.e90post.com/forums/showthread.php?t=784416 Walnut blast at 45k (see https://www.e90post.com/forums/showthread.php?t=1029521). Installation of a oil catch can (which I was skeptical of) has really helped with intake valve build up of oil/carbon. Replaced valve cover gasket (VCG) at 60k. Replaced right front axle assembly (CV joint - I have an XI model). Not too hard to do, my left one is just starting to make noise. Replaced plugs numerous times and Replaced injectors when I did VCG. I'm pretty religious about changing oil more frequently than most. (Flame suit on!) Every 5k or even just 3k if I think I drove it hard. (I used to track this car extensively - it has over 60 track days.) My alternator failed twice. Major biotch to change it. Took the first opportunity to replace the oil filter housing (OFH) gasket. Yes, I had to remove the frigging OFH to replace the alternator. https://www.e90post.com/forums/showt...5#post20322995 I have really, really enjoyed the coilovers from KW that I put on many years ago. They are still nice and improved the quality of handling and even the ride greatly. I do not use run flat tires, they are a fail. (Well, I haven't tried the newer ones, but the thick sidewalls just remove some of the feel.) Best of luck to you. Join the BMWCCA and do local events! I instruct for the Rocky mountain region. Cheers!
12-07-2018, 02:39 PM | #4 | |
Rep 7
12-07-2018, 02:42 PM | #5 | ||
Rep 7
12-07-2018, 02:53 PM | #6 |
Rep 13,103
12-07-2018, 05:55 PM | #8 | |
Rep 7
12-07-2018, 06:39 PM | #9 | |
Old Guy
133
Rep 305
Drives: 335is DCT
