help what are there connectors and what do they do???
12-06-2018, 09:30 AM | #1 |
Rep 44
new to the forum, tried searching but I have no idea what these are so dunno how to even go about searching for them.
got a 2008 335i, had the car on a lift and saw corrosion on what seems to be the outside of the battery tray. |
12-06-2018, 09:39 AM | #2 |
Is it the shoes!?
3884
Rep 5,112
The small one looks like the battery vent tube, the other ones I have no idea. One of them looks like a big red positive cable, so the other must be negative.
Clean the area and see if it's just mud/gunk and not rust. If it's rust, you'll want to take care of it now while it's minor. |
12-06-2018, 09:44 AM | #3 | |
Rep 506
2010 335I Xdrive
You're not really driving if you don't have 3 pedals. |
12-06-2018, 09:50 AM | #4 | ||
Rep 44
OTO335i144.50 |
12-06-2018, 10:11 AM | #5 |
Rep 164
You caught this at a good time, highly recommend cleaning up this area, sand, respray. It would not at all be difficult but do some research and prep on how to get that rust out.
Its becoming more than surface but still treatable.
2009 e90 335i
6MT*Sport Package*Factory Location VRSF Inlets/Outlets*VRSF 7"HD IC & DCIs*FTP Low Temp Oil cooler Thermostat*VRSF DP & 335is Mufflers*Turbosmart Diverters*Custom Tune*550 Clutch & Delay Valve Removed*e93 M3 FSB*Custom Seeping Oil Pan |
12-06-2018, 11:04 AM | #6 | |
Rep 4,031
Here is a TIS procedure for changing one of the two cables that shows BOTH from the battery compartment (inside) and explains function: https://www.newtis.info/tisv2/a/en/e...ble/1VnXWUgICS The corrosion/rust shown in your photos suggests that either you have/have had water in the battery well, or worse yet, a defective voltage regulator causing more than 15.0V alternator output, boiling battery acid that is VERY corrosive. In either event, I would suggest: 1) checking system voltage with engine running to make sure <15.0V; 2) removing the battery cover, removing the battery, and properly removing/treating any rust/ corrosion present on the inside of the well; 3) With battery removed, disassemble & clean the transfer point connections & insulators, as well as treating the rust around the "passthrough" holes in the chassis. BTW, you appear to have a "NOW-small" hole in your R muffler at the hanger-rod weld, and corrosive exhaust on that area can't help. High-temp epoxy can buy you some additional muffler life. George |
PassiveDefect6.50 |
12-06-2018, 11:20 AM | #7 | ||
Rep 44
the car sat for 3 years with a stone dead aftermarket battery on grass so both I guess : battery been replaced with an OEM one for few months now. gonna take it out and examine the rust from the inside will update with repairs |
