E90 Spinning nut welds inside subframe.
12-06-2018, 12:11 AM | #1 |
Rep 2
I have been doing downpipes and replacing O2 sensors on my 2008 E90 335i.
Just below the downpipes there is a v cross brace going from the subframe in the centre angled back behind each wheel. It is secured with 6 nuts in total. I am struggling to remove a few of them as they are spinning to no avail. I have tried everything just need some advice on the best option. Im guessing they were overtightened or siezed in place from the previous owner and I snapped the weld nuts loose inside when I attempted to remove them. I want to cut the bolts and try removing the nuts with a magnet out the end of the subframe. Then cut a square out of the subframe to reweld a new nut and then patch up as strong as possible. Double layer if need be. What is my subframe made out of to re weld? And can I cut a small hole to re-set a nut? Does this compromise the strength of the subframe? Any help is appreciated, thanks. |
12-06-2018, 12:39 PM | #2 |
Rep 474
here is the diagram from realoem, figure out which ones are broken loos and if they are #7 or #8, if yes then reach with a wrench above the cross member and get the bolt out. That is what broke on mine when I did the oil pan gasket.
http://www.realoem.com/bmw/enUS/show...diagId=31_0814 Or post pictures of which ones are broken on yours. |
12-09-2018, 01:08 AM | #3 | |
Rep 2
12-09-2018, 07:00 PM | #4 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
I had the same exact problem.
Use BMW FANS to get the part number for new fasteners. You will have to cut the bolts off with a sawzall. Get a Diablo carbide tipped blade. It will go through the bolts like a hot knife through butter. I Dremmel May also do the trick, but you will go through a lot of blades. Also, when it's all said & done and your putting the V bar back into place with the new nut fasteners, slather the bolts up with some anti-seize. I'd use some nickel based anti-seize on the bolts that secure the downpipes to the exhaust flange. https://www.ecstuning.com/b-genuine-...h/31106779393/ |
12-09-2018, 08:02 PM | #5 | |
Rep 474
In my case I had only one do that after the car living all of it's life in the rust belt (northern Illinois). |
12-09-2018, 08:42 PM | #6 |
Rep 78
+1 on the Diablo blades. I literally cut my brake rotors in two with these on my truck. This after my 10 ton puller pulled its hooks right through the rotor. Next time I am working on front rotors that are completely seized on the hubs I am going straight to the Diablo. Sorry a little off topic but man those are great!
