Please delete
12-04-2018, 01:07 AM | #1 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Please delete
Please delete
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
12-04-2018, 06:42 AM | #2 |
Rep 99
I would send them back. That's not acceptable. My rotors came individually boxed. I just hope they don't make you pay for shipping them back. They're heavy and it will be expensive.
Good luck!
M-Tech Aero Kit with Custom Quad Diffuser
ACS Rear Spoiler, ACS Roof Spoiler Quad Magnaflow Exhaust,AFE Intake, Sprint Booster |
12-04-2018, 08:26 AM | #4 |
Hoonigan
6848
Rep 3,000
Drives: '09 328i, '98 Wrangler
I'd contact them, every experience I've had with them has been great.
To be honest though, I think those are perfectly okay to use. If they offer you a partial refund or something I'd take it and use them. The scratching only seems to be on the mounting surface, and looks like it was caused from sand or something that got into the box.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
12-04-2018, 08:59 AM | #5 |
Rep 6,290
If the zinc coating is off of the hat I would definitely looking to replace them. You'll most likely get ugly brakes (rust) if you don't.
12-04-2018, 09:34 AM | #6 |
Rep 420
Drives: E92 335XI (sold)/E92 M3 (sold)
FCP has great customer service. They will take care of this for you. I have had one experience where a struct was shipped in just the product box and it was almost split in half when I received. I let them know and they took care of it immediately.
12-04-2018, 09:34 AM | #7 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
That zinc coating will be gone in minutes on the braking surface and within months on the wheel mounting surface and everywhere else. You might as well keep them. If you want them to stay looking good, sand and prep the rotor hat and then paint with a quality spray of your choosing.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
feuer4275.50 IllSic_Design2124.00 |
12-04-2018, 09:37 AM | #8 | |
Rep 6,290
Fritzer944.50 |
12-04-2018, 09:37 AM | #9 |
Rep 13
Fritzer, apologies for the the damage here, often times rotors will be packaged from the manufacturer hat-on-top-of hat like this and will leave some scuffs which is normal. However, the damage or chips on the rotor surface is not acceptable and we can certainly have these swapped our for you for replacement components right away.
You said you have already emailed us in but you can also reach out to me directly at Mike@fcpeuro.com and I can see about getting new units sent your way and pick up these from you as soon as we can. Just let us know, and we will take care of you! Best, Quote:
12-04-2018, 09:56 AM | #10 | |
Sua Sponte
1299
Rep 2,850
You can either get two piece rotors with aluminum hats or paint them.
12-04-2018, 10:04 AM | #11 | |
Rep 420
LMB335IS1299.00 |
12-04-2018, 10:11 AM | #12 | ||
Rep 6,290
Because my dad's daily driver has the lower quality coatings, the one that are in black I think it's called, or maybe they are just painted but I'm sure it's some kind of electro applied coating. Anyways his have not rust at all and I am in Ottawa. I also got the same type of coating for my front discs and had to paint my rears since couldn't buy them with it. I guess I'll see my self personally how it holds up, but my dad's are still great looking after a few years. I guess zinc coating isn't that good then. I had in mind that zinc coatings were higher quality than the one in black EDIT: The black coated ones are electrophoretic coated. That's the term I was looking for. |
Fritzer944.50 |
12-04-2018, 11:15 AM | #13 |
Is it the shoes!?
3884
Rep 5,112
If you don't mind the surface imperfections, it'll probably be fine. The rotors were poorly packed, and each should have been in individual boxes. I would still let them know so that they can improve their quality control.
12-04-2018, 11:28 AM | #14 | |
Rep 1,753
12-04-2018, 11:39 AM | #15 | |
Robot
1685
Rep 2,190
Are you saying they won't last either? Is there anything that will stay clean and rust free? |
12-04-2018, 12:11 PM | #16 |
Rep 9,206
wow, thread for this? Just instal the rotors. What do you expect will happen when you mount a wheel on there? Or after few heat cyclces and season changes. Want something that will stay clean and rust free? Get carbon ceramic rotors with aluminum hat
12-04-2018, 12:16 PM | #17 |
Rep 2,243
Drives: 2007 328i / 2014 M235i
They look fine and remember surface rust is nothing; it is nature's way of protecting the steel from further corrosion. What is more important is the steel quality. I always use some anti seize on the top hat of the rotor, it prevents excessive corrosion.
12-04-2018, 12:19 PM | #18 |
Rep 2,202
Honestly this has been the case for me and the pair of front coated rotors I have for a couple years now. The Hats do not rust at all. The stock rears look like shit.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
TheMidnightNarwhal2657.00 |
12-04-2018, 02:01 PM | #20 |
Rep 151
He didn't exactly trash them. He said he contacted them and was asking for opinions about using as is...
12-04-2018, 07:14 PM | #21 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
You could always buy a high temp brake paint like G2 and paint the hub portion black. I have seen people do that in Michigan where we use Salt on the roads and the hubs hold up nicely against rust, over time.
Only thing is G2 paint is like $40.00. Once you mix the solution into the paint, you've got like 12 hours to use it, and then it turns hard as a rock. One can will cover 4 rotor hubs very easily. |
