BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Oil change
      11-26-2018, 11:02 AM   #1
tcw495
tcw495's Avatar
271
Drives: F90 M5
Oil change
How frequently are you all changing your oil?
      11-26-2018, 11:15 AM   #2
Alberta
Alberta's Avatar
2028
Drives: F90
When the car tells me to
      11-26-2018, 11:29 AM   #3
tcw495
tcw495's Avatar
271
Drives: F90 M5
I want to say that is like 7,500 miles or something...just making sure it isn't recommended to do it sooner or anything.
      11-26-2018, 12:12 PM   #4
Vic55
Vic55's Avatar
19242
Drives: 2023 BMW M8 Competition Coupe
exactly- same here but I do think driving habits can adjust the time frame.... if one is light on the pedal the next service could be the annual one but if you drive aggressively the service indicator could adjust. This was the case with my 2016 M5 (all of my M's that had such a process) because after my 1200 mile service, the indicator came up again mid calendar year to reservice the car (circa 5500 miles).
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      11-26-2018, 03:19 PM   #5
marcvtec
Drives: M5
I change mine every 5,000 KM. always - I love clean oil in my car, but I also keep them for like 10 years.
      11-26-2018, 04:15 PM   #6
fun2drv
fun2drv's Avatar
Drives: '23 M5 Comp
2023 BMW M5  [10.00]
2023 BMW M5  [0.00]
Little off topic, but has anyone figured out how much oil it takes to do an oil change? You can't drain all the oil because the oil cooler in front of the car is lower than the drain plug. I like to do an oil change in between the recommended intervals and I do those myself.
      11-26-2018, 05:03 PM   #7
marcvtec
Drives: M5
just did it 2 weeks ago - 8.5 - 9 litres, then check it- should be good.
maybe add 100ml or 200ml if needed.
      11-27-2018, 03:02 AM   #8
fun2drv
fun2drv's Avatar
Drives: '23 M5 Comp
2023 BMW M5  [10.00]
2023 BMW M5  [0.00]
Thanks a lot!!!
      11-28-2018, 04:42 PM   #9
Gassy
Soporificist
160
Drives: 2019 M5- Rhodonite/Aragon
Is there it a DIY video out there on how to change the oil? When I squeeze under the chassis all I see is protective armor!
2019 M5 Rhodonite Silver// 2016 M4- retired// 2011 750i- retired// 2004 740i- retired//
2001 740i- retired// 1998 M3- retired
      11-29-2018, 08:03 AM   #10
marcvtec
Drives: M5
there is a circle cut out and you can see the oil filter
      11-29-2018, 09:00 AM   #11
Hashtag_M_Rated
///M Driver
Hashtag_M_Rated's Avatar
Drives: 2018 First Edition M5
2018 BMW M5  [0.00]
I eventually need to learn to change my own oil! But for now it's still under the complimentary services.
Currently driving: 2018 M5 First Edition
Vehicles Owned: 2014 M5 ZCP, 2017 M3 ZCP
m5post
