11-12-2018, 03:06 AM | #1 |
Rep 21
NBT EVO ECU flash failed
Hello,
I am writing this new post because I am doing a retrofit from HU_ENTRY to HU_NBT2 (NBT EVO). I would like to completely reflash my HI_NBT2 because this one had the CP (component protection) active. The first step I did was to start the job "HU_SPECIAL_NBTEVO_CLEAR_V850" with the tool "tool32". HU_SPECIAL_NBTEVO_CLEAR_V850 comment : deletes Persistency on NBTevo V850 important: Reflash+Recoding needed afterwards as also logistic When performing a SVT reading I now have this in the ECU "HU_NBT2": The second step is to fully reflash the HU_NBT2. For this I followed the procedure below: 1) Go go comfort mode (TAL-Calculating) - read FA then save - active FA - read SVT Actual then save (SVT_tal_1) - create an SVT target Under KIS/SVT Target Calculation Strategy, i select "Complete Flash". I Select I-step (shipm : Do a KIS/SVT Target Calculation Click on the button "HW-IDs from SVTactual" Then save as SVT_sol_1 I have 2 warning : WARN events: "[] Warning 1680, no application data list available for ECUId:HU_NBT2_0x63, (Exception: error while switching to extended diagnostic session), [] Warning 1680, no application data list available for ECUId:PIA_MASTER_0x63, (Exception: error while switching to extended diagnostic session)" [C382] 2) Go to expert mode (TAL-processing) - Load TAL (SVT_tal_1) - Load SVT Target (SVT_sol_1) - select "read FA" button - click the button "Read VIN", then select the "read VIN out of FA" But unfortunately I have no line named "HU_NBT2" Do you know why I can not flash this ECU? Do I have to correct the warnings in the "KIS / SVT Target Calculation" step? |
07-02-2020, 01:55 AM | #4 |
Rep 1
Hello Kubax86,
I've got the same problem. Can you help me with that? I've these two errors by TAL calculation WARN events: "[] Warning 1680, no application data list available for ECUId:HU_NBT2_0x63, (Exception: error while switching to extended diagnostic session), [] Warning 1680, no application data list available for ECUId:PIA_MASTER_0x63, (Exception: error while switching to extended diagnostic session)" [C382] I hope you can help me, Kind regards, Tijs |
07-23-2020, 12:54 PM | #7 |
Rep 3,050
Hey, Sure, message me your issue on PM Thanks
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
10-29-2020, 06:21 PM | #8 |
Rep 7
