DIY: Smoked Turn Signals
07-09-2008, 04:23 PM | #1 |
Rep 1,239
After custom fitting a sheet of tinted lamin-x to the front and rear signals for a few months, the thickness of the film (17 mil) started to get the better of me. Since the film was so thick, there was a very noticeable outline of where the lamin-x was placed and frankly, looked really cheap... so I decided to spray tint them
Now the directions for most spray tints i.e. VHT Night Shades instruct you to clean the surface of the lens then spray it directly on. This is all wrong and the final product will suffer greatly not only in terms of shine and finish, but also with durability. My car is a daily driver and here up in the Northeast, winter salt takes a toll on any unprotected finish. This DIY is how to spray tint that not only looks good, but will also stand up to the elements. Time for DIY : ~2hrs Parts needed - 800, 1500, 2000 grit wet/dry sandpaper - Blue painters tape - Newspaper - Soapy water (in both spray bottle and bowl) - 2 cans Tint spray (I used a spray tint made by Tamiya found at most hobby stores. Two cans were plenty for the signal lights but if you're doing the entire lamp, buy more.) - 1 can Clear coat (I used Tamiya clear. Again, buy more if you're planning on doing the entire lamp) - Buffer (PC 7424) - Medium and Fine Polishing compound (Menzerna IP & FPII) Step 1: Mask Mask the area you want to tint with blue painters tape. Step 2: Surface prep Dunk the 800 grit sandpaper into the bowl of soapy water, spray the area to be sanded a few times and begin sanding. Continue wetsanding while keeping both the area and the sandpaper well lubricated. Stop when you have sanded away the gloss. Note: That's soapy water in the Zaino bottle. Step 3: Mask again (if necessary) My sanding job ate away at the painters tape so I re-taped and masked a larger area with newspaper in preparation for paint. Step 4: Painting Not necessary, but a trick people like to use when painting with rattle cans is to lightly heat the can before spraying. This atomizes the paint better which allows for a more even coat. Do this by running the can under warm water for 5 seconds and then shaking the can. Repeat until the can is slightly warm after shaking. Caution: Do at your own risk. Heating a sealed canister with a propellant may cause the canister to explode. Warm water only. Don't think you can save some time by breaking out your heat gun . Paint using long even strokes. Start spraying before the area and end after. Remember to use lighter coats instead of thicker coats to prevent running. Allow 5-10 minutes in between coats. Stop when you have achieved the proper darkness. Apply the clear the same as you did the tint. Three coats of clear is sufficient. After first coat Since I wanted a darker tint, I sprayed an additional 6 thin coats. Here is a picture after the clear. Step 5: Removing orange peel The purpose of this step is to remove the orange peel that has occurred during the painting process. Gently wetsand beginning with the 1500 grit then work up to the 2000. It is especially important to keep the surface and sand paper wet during this step as the finer grit sandpapers tend to gunk up quickly. Your goal here is to remove the orange peel while minimizing the amount of clear removed. It may help to wipe down the area occasionally to make sure you aren't sanding through the surface layer. If you don't know what orange peel looks like... After sanding, your lights should look like this: Step 6: Polishing At this point, you're probably wondering why you just ruined your perfectly glossy finish. Before you send me an angry pm about how you just wasted an hour prepping and painting just to end up with a horrible product, break out your buffer. For this process I used combination of an orange pad with IP followed with a white pad with FPII, with an isopropyl wipedown in between products. Follow up with your favorite sealant and voila, you're done! |
07-09-2008, 04:52 PM | #2 |
Feeling Blue.
116
Rep 801
Drives: I12 i8,f10 M5,e89 IS,F1 6S35i
nice write up i just decided to remove my tail light tints yesterday, because of the lack of gloss.. i wish i read this earlier
07-21-2008, 08:19 AM | #3 |
Rep 9,946
A+. wait if i don't own a pc? wat can i use?
07-25-2008, 03:34 AM | #6 |
Rep 1,534
Drives: jet black 335i coupe
is this removable?
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
03-24-2009, 01:31 AM | #9 |
Rep 112
the side markers look great!... is the light output the same? after tinting/ smoking them?
~*RELUX Brands/ Company's in the making*~
06' Smokey Granit Lexus IS350....SHADOW....~*SOLD*~ 08' Titanium Silver e92(335i)....SILVER SURFER.... 09' Black w219 cls63amg... The Rocketeer.... http://tommybooyyyy.wordpress.com/ |
05-06-2009, 09:23 PM | #14 |
Rep 1,813
Going to do this either tomorrow or the next day. So if we dont have a buffer we can still do it by hand right?
2006 E90-Running like brand new again. Take that insurance company 95 S14-Sold 95 S14 Rb25det-Vrom Shhh |
06-13-2009, 05:11 PM | #15 | |
Rep 69
06-13-2009, 05:35 PM | #16 |
Rep 1,239
Menzerna Intensive Polish (IP) is basically a medium strength polish. Menzerna Final Polish II (FPII) is a light strength polish. You don't have to use only Menzerna polishes though; any brand medium polish followed by a light polish will work just the same. For sealant, top it with the wax/sealant you would normally use on the rest of your car. Hope this helps!
05-02-2014, 06:19 PM | #17 |
Rep 130
Drives: 2008 328i Sedan Sports
I am not finished with this. Tomorrow I will smooth this down and possibly clear coat if you think that makes sense. I had rain approaching within a few hours and had to get the assemblies back in plus I wanted it to cure back at my garage. Was my first time and I went one coat too dark but it still works
2008 E90 328i Sport Sedan
335 189 wheels/Eibach Pro-Kit/H&R 10&12mm/K&N/Charcoal delete/LED Past:2012 R56 MINI S/1992 E34 525i/1989 E30 325ic |
05-03-2014, 04:09 PM | #19 |
Rep 130
I actually did the 2000 grit today and hit with final Polish by hand. Then 4 clear coats lacquer only. When that cures I will repo list with machine.
Here is an experiment I did today from SlickMod. It is 20 or 35% tint that is precut. And can put on using the wet method. Very cheap way to change it a little and totally removable. If doing again I would use a hair dyer and maybe wrap the curves but overall I like it.
