11-09-2018, 11:22 PM | #1 |
E50 TUNE | XHP STAGE 3 | METH INJECTION | FBO | AWE FULL EXHAUST
Rep 12
Custom BMW Headlights SoCal
Hey Guys,
I'm trying to see if you guys have any information on any shops that does custom BMW headlights in SoCal area, around LA or SD. I still have the ugly stock halogen headlights and I need to upgrade them. I have 17' BMW 330i B48. TIA !! |
11-10-2018, 11:04 AM | #2 |
¯\_(ツ)_/¯
947
Rep 1,762
Buy either OEM projector/LED headlights or DEPO lights and install them yourself. Very easy to do
Btw, you should have posted this in the regional section.
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
11-10-2018, 08:50 PM | #3 | |
Rep 12
Sorry pretty brand new to this forums, but thanks for the heads up. |
11-12-2018, 10:24 AM | #4 | |
Rep 1,397
Second piece of advice: make sure that you adjust, or should I say use the adjustment, of the installation screws. They are reverse threaded and are seemingly difficult at first to maintain position, but this is for good reason. If you leave them fully threaded in, the headlights will be aimed down too far causing full adjustment of the headlight to still have too low of a cutoff and what I call the "castle affect." I recommend at minimum two threads of the reverse nut out. You will see what I am talking about if you order them. If you need further clarification, let me know. |
11-12-2018, 04:37 PM | #6 |
Rep 12
Nothing crazy man, just to get better visibility and distance cause these stock halogens sucks so bad it's crazy, I seen they're site and they do have some quality headlights but pretty expensive!!
11-14-2018, 10:04 PM | #7 | |
Rep 12
