Front Axle Replacement and Seals
10-18-2018, 11:24 AM | #1 |
Rep 355
So my front axle just blew out and I am getting a notchy feeling when accelerating on turns and get a clicky noice. I was told by the Indy shop that I should replace the axle seals along with the axle.
How hard is it to replace the axle seals? I was planning on replacing the axles myself but I was told by the INDY shop that replacing the seals is a lot more involved... Do i need any special tools?
2008 | e92 | 335xi | 6MT | VRSF FMIC| VRSF DPs | VRSF CP | S&B DCI | FORGE DV | MHD Tune | BMW PE
2019 | w205 | C63s AMG |
10-18-2018, 04:27 PM | #2 |
Rep 1,893
Once you've got the axle out, seal replacement is no big deal. You can lever the old one out with a screwdriver. You can use a big socket for a seal driver or just use a plastic faced hammer to evenly tap in the new seal. Go slowly and don't get the new one cocked.
HooDat31.00 |
10-19-2018, 09:46 AM | #3 |
Rep 355
Do you think I'd need an axle puller/remover or is a flathead/wedge good enough? and is an alignment required? thank you
10-19-2018, 10:40 AM | #4 |
Rep 776
Seals are easy. Just take your time tapping the new ones in. New one should come with new C-clips. Be very careful putting in a new one. I had a BMW mechanic buddy get one stuck in my car. Wouldn't go in all the way, or out AT ALL. Total nightmare.
You will defiantly need an alignment after, you have to disconnect the entire lower suspension from the sub frame to get the axle out. |
HooDat31.00 |
10-19-2018, 01:00 PM | #5 |
Rep 1,893
Getting the axles in and out can be trivial or a challenge depending on the tolerance of fit for various components.
Getting the old axle out of the wheel hub is no problem even if the spline is tight because you are going to discard it anyway. Just whack the threaded end with a sledge. Getting the differential end out can be difficult because space is tight and there is not always a convenient ledge to pry from. I recommend a tool like this: https://www.ebay.com/itm/Steck-Manuf...Mrb:rk:10:pf:0 Getting the new axle in can also present issues. The C-clips provided with many aftermarket axels are too large and can break or simply refuse to allow the axle to seat. I'd recommend buying new OEM C-clips or at least recover the old ones from your worn axles. C-clips aside, seating the differential end is not a problem but getting the spline far enough into the wheel hub to place the axle nut can be a bitch. For that, I'd recommend a tool like this: https://www.ebay.com/itm/7Pc-Drive-S...97.m4902.l9144 |
HooDat31.00 |
10-22-2018, 04:56 PM | #6 | |
Rep 355
10-25-2018, 08:26 AM | #8 |
Rep 718
Not sure how similar the front Axles on an e92 are, but I replaced the axles on my e46 several times.
The e46 axle had little ridges on the hard part close to the diff. To remove them from the diff, I got under the car, put a long screwdriver against that ridge and tapped it out very easily. If you inspect the new axle, you should be able to figure out what I am saying. For the e46 I actually had a very hard time getting the axle out of the hub, so you may want to have a puller on hand just in case. I pieced together two pullers that autozone loans for free and it saved me a lot of hammering.
HooDat31.00 |
10-25-2018, 10:30 AM | #9 | |
Rep 1,893
HooDat31.00 |
10-25-2018, 12:36 PM | #10 |
Rep 355
Thanks for all your input guys, I have ordered the parts and will try to tackle it myself with the tools I have. If i am unable to I found an indy that will charge me only $200 labor for both axle and seals to be replaced.
10-26-2018, 12:09 PM | #11 |
Rep 718
For $200 I would 100% pay the indy to do it. It's definitely a job you can DIY, but every time I've done it I always run into some extremely frustrating part and the whole thing ends up taking way longer than it should.
