10-09-2018, 05:28 AM | #1 |
Rep 115
Today my M2 LCI developed a fault with its rear Right hand LED indicator!
It's flashing fast but still lights up ! Anyone else had this problem? Left work tonight all ok ? |
10-09-2018, 05:18 PM | #2 |
Rep 31
Had same issue with right rear and intermittent indicator failure etc, took it to my dealer and its was replaced full light under warranty
[B] BMW M2 LCI - BSM DCT | MPE with Carbon Tips | Black Kidney
Euromeister50.50 |
10-09-2018, 05:47 PM | #3 |
Rep 6,944
Drives: 2018 M2 AW DCT
I started a thread on this subject several months ago. Mine hasn’t acted up in a few months so I am ignoring the problem right now until my next service.
Euromeister50.50 |
08-06-2019, 04:28 PM | #4 | |
Rep 115
Rear Right indicator fault again.
They have checked it out for the second time but will not change out the rear lighting unit under warranty ?. I know others that have had this work completed under warranty ? |
08-06-2019, 04:42 PM | #5 | |
Rep 2,379
08-06-2019, 04:46 PM | #6 | ||
Rep 115
Vines
Still registered a fault but then is ok ? |
08-07-2019, 12:37 PM | #8 |
Rep 115
LED Rear light replacement
After emailing and speaking to customer services today pressing the safety side BMW UK have agreed to replace my LED rear light unit!
guess what they are on back order ! |
08-07-2019, 01:17 PM | #9 | |
Rep 2,149
I spoke with mine again today, since I was in there for something else, and he agreed to replace my driver's taillight too. Just gotta schedule an appt. for him to pull the error code to send to BMW. Mine is at the point where it's completely un-usable in the rain or after a car wash. Blinks fast constantly and throws a warning. I guess it is technically usable, but it's definitely embarrassing and annoying to use like that. Based on another thread, it seems like a design flaw that is letting water in, so not sure if the issue will come back or not, but I hope not. |
08-07-2019, 09:03 PM | #11 | |
Luxury at the redline :)
9105
Rep 7,563
The rate that a flasher unit blinks at is controlled by how much current flows through it. Reduction of current to a parallel circuit due to a overloaded ground and flash rate increases. The Pre-LCI used three separate ground wires to combat this issue, the LCI only uses one, for some strange reason. The only solution is to DYI a ground for each tail light separately to the chassis, independent of the vehicle's common ground. I get that most folks are just going to ignore this and just keep fruitlessly bitching to dealer but it's not going to solve anything. Just don't say not one told you so. https://www.newtis.info/tisv2/a/en/f...ess/1VnZ8zZX2B LCI one VS Pre-LCI three ground wires: |
