07-02-2008, 06:10 PM | #1 |
Sleepy Member, wishing I was on the road.
34
Rep 280
Aftermarket USB Retrofit
I searched for this topic and found no satisfactory answers.
I Ordered my BMW w/o the ipod/USB option thinking it wasn't that cool. Now I'm reading that you can use a pen drive or anything else that acts like a hard drive. ...and now I want it. How can I get the I-Drive functionality with usb drives if I didn't order that option. I couldn't find any kits that would give it to me. HELP PLZ
2003 Ducati '996
2008 M3: Sparking Graphite, Red Fox Standard, 19s, Premium pkg, Tech pkg, Premium Enhanced Sound, HD Radio, Heated Front Seats. |
07-02-2008, 07:09 PM | #2 | |
Rep 12,997
07-07-2008, 12:12 PM | #3 |
34
Rep 280
OMG thats not as simple as plugging in an extra cable is it? So I'm guessing i have to buy this kit from the dealer?
2003 Ducati '996
07-07-2008, 06:33 PM | #4 |
34
Rep 280
Dealer just quoted me $1,200 for parts and labor!!
2003 Ducati '996
07-07-2008, 10:20 PM | #5 |
Rep 1,664
Wonder how much the parts are?
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
07-08-2008, 07:09 AM | #6 |
Rep 12,997
Unfortunately, no. The OEM retrofit is a complete integration of the USB port with all the audio components in the car (radio, Nav, TCU) as equipped.
07-08-2008, 11:32 AM | #7 |
34
Rep 280
Parts were $450+tax.
So there is no aftermarket 6FL equivalent, or something that is as good?
2003 Ducati '996
07-08-2008, 01:11 PM | #8 | |
Rep 12,997
Or, I think that you could end up paying slightly over half of the OEM 6FL retrofit $1200 dealer cost that you posted if you get the Dension Gateway 500 USB aftermarket module, and the installation would be way easier because it uses the OEM CD Changer connection: http://www.e90post.com/forums/showthread.php?t=84125 You might need to get an OEM CD Changer (you can borrow one from a good -a very good friend is much better- friend with an E9x and save some money) as you will need the CD Changer physically installed in your car for programming. If your car already has a CD Changer then installation is virtually plug 'n play, as no programming will be needed: the Gateway will mimic a CD Changer, with full display and control interface thru your OEM HU or iDrive. |
07-08-2008, 04:25 PM | #9 |
34
Rep 280
Hmm... the post doesn't give me the warm and fuzzy about its functionality. Has anyone else installed the dealer retrofit themselves?
2003 Ducati '996
07-08-2008, 11:09 PM | #10 |
Rep 12,997
12-09-2008, 07:12 PM | #11 | |
Rep 2
12-09-2008, 07:32 PM | #12 |
BimmerPost Supporting Vendor
8113
Rep 18,808
There is:
mObridge - iPod integration kit for e90/91/92/93 3-series http://www.europeanautosource.com/pr...oducts_id=1651 The mObridge kit is light years faster than the BMW kit, USB compliant to support charging of current model iPods/3G iPhone and firmware updateable. If anyone has used the OTC BMW iPod kit, you'll immediately know what I mean. As far as the Gateway goes - it's beyond buggy in the BMW platforms.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
12-28-2008, 01:06 PM | #13 | |
Rep 178
Drives: 318ti/r1200c/335i
OEM iPod Kit removal for mObridge-iPod intergration
The slow response may be due to the old iPod, I just don't know. I tried a nano that responded quicker, but it also had considerably less content. FYI: The iPod kit is listed at $319.95 (I got a 10% discount) and the labor was $152/hour for 3.0 hours. I ended paying about $750.00...$1,200.00 is too expensive. tom: Since my e92 was reprogrammed after the OEM iPod kit was installed, would I need to install a CD changer and have the car reprogrammed prior to installing the mObridge kit? I think you already know that, to use the OEM iPod kit, the CD Changer may no longer be available as the kit takes over. Any info is appreciated! Thanks!
335i-e92 |TiAg |ZSP |ZPP |NAV |CA |PDC Gray Pop.Wood |HD Radio |Rear Shade |Cold Weather |
12-29-2008, 01:59 PM | #14 |
34
Rep 280
Think its worth $750? I don't... oh hindsight, why do you spite me so.
2003 Ducati '996
12-29-2008, 02:44 PM | #15 | |
8113
Rep 18,808
02-23-2010, 10:49 AM | #17 |
34
Rep 280
Can I resurrect this topic? I really am sick of using my ipod cable and I went to buy the ipod retrofit kit:
65 41 0 427 467 USB/iPod interface retrofit kit Turns out this is the wrong one. So before buying the correct OEM one, I would like some opinions on the mObridge kit. Is it really better? Here are some questions, 1) I don't have a cd changer, how would reprogramming work? Will the dealer squak about warranty? How much is this? 2) How OEM does the mObridge interface seem? 3) Any other opinions of 6FL vs mObridge ? Thanks guys!
2003 Ducati '996
02-23-2010, 08:11 PM | #18 | |
8113
Rep 18,808
1. Larger paging file means faster browsing 2. USB/Firewire based charging supports all iPod models (except shuffle) 3. 24 bit ADC sound 4. End user upgradable via SD Card slot, never obsolete 5. Random, Repeat, Scan options 6. AUX input for other devices Installation method is exactly the same as the BMW version.
02-24-2010, 10:38 AM | #19 |
34
Rep 280
Thanks Tom,
Don't know what the BMW installation is like, but from the box and description of the mobridge, it looks like just a single plug from the cd changer, then your inputs. Sounds like a 30 minute job, right? What about dealer programming? Should this be no issue?
2003 Ducati '996
02-24-2010, 12:27 PM | #20 | |
8113
Rep 18,808
Coding is required if there is not a CD Changer present. We can perform the coding in-house if you would like to DIY the mObridge on your own and learn a bit about your M3, which we always encourage.
02-24-2010, 12:37 PM | #22 |
34
Rep 280
Definitely would like to do the coding on my own. Does that cost more to do the coding in-house.
Just to confirm the compatibility, I have an '08 M3, w/ enhanced audio, i-drive, nav, bluetooth, no 6fl, and no cd changer. Still works? And yes, it would be nice to know if you can watch movies off your ipod or iphone, but I'm fairly sure you cannot. Unless you have a different kit that does both? Thanks, Tom
2003 Ducati '996
