Coolant Pump Thresh Set Point
08-22-2018, 08:48 AM | #1 |
Rep 1,753
Does anyone know if there is a way to adjust the Coolant temperature target so that the coolant pump kicks in more or less depending on that set point. I am sure there must be a value somewhere. I Notice my coolant temp stays at 110 degrees Celsius.. Sometimes the pump kicks in "faster" and drops the temp briefly lower. So i know it can be lower.
08-22-2018, 09:05 AM | #2 |
Rep 7,215
There are 3 setpoints - 110c is for low loads/cruising. At high loads it drops to 80c. Theres also a medium setpoint.
The engine is designed to run at 110c so I dont think you really want to make it run colder, it will just make it less efficient. |
08-22-2018, 09:14 AM | #3 |
Rep 1,753
That makes alot of sense.
08-22-2018, 09:58 AM | #4 |
Rep 38
set mine in sport mode in MHD. I bought pump from FCP with lifetime wrrty so im not worried about running the pump more often
Sport Mode • Coolant normal 95c (104c Stock) • coolant high 90c (95c Stock) • Coolant high+kft 80c (85c / 80c Stock) (This mode is activated at full throttle) • Amb threshold for high mode 27c (32c Stock) • Amb threshold for high + kft 32c (37c Stock) Race Mode (only for drag race application) • Coolant normal 85c(104c Stock) • Coolant high 85c(95c Stock) • Coolant high + kft 80c(85c / 80c Stock) (This mode is activated at full throttle) • Amb threshold for high mode 22c(32c Stock) • Amb threshold for high + kft 27c(37c Stock) Your car will run cooler and the oil temperature will also drop slightly |
Pladi719.00 |
08-22-2018, 11:02 AM | #6 |
Art Collector
2427
Rep 3,450
FWIW, I find my car rarely moves out of that 80-90c territory. This is city driving mind you, but I'd be curious whether this is typical.
Next time I'm on a flat highway I'll check out my temp and see if it's ~110c...
When I'm dead, just throw me in the trash.
08-22-2018, 11:19 AM | #7 | |
Rep 6,301
Unless I'm a bit confusing things, both your readings won't be the same right? |
08-22-2018, 11:31 AM | #8 | |
Art Collector
2427
Rep 3,450
Now, I didn't consider the fact that perhaps the N54/55 have different setpoints than the N52...
08-22-2018, 11:33 AM | #9 |
Rep 6,301
Oh okok my bad yeah, I always forget about those I should give it a try once to read them.
08-22-2018, 11:38 AM | #10 |
Art Collector
2427
Rep 3,450
No problem!
08-22-2018, 12:08 PM | #11 |
Rep 1,753
Yes oil and coolant temperatures are almost always different except for cold starts. I have been monitoring the coolant temperature on a long highway drive it stays solid 110 C. It should be the same for 328i. Oil temp is different obv for turbo, hence the gauge.
