07-15-2018, 08:38 PM | #1 |
Rep 10,473
Wheel Cleaner
I am sure there are about 10,000 posts on this, but let me give the exact scenario.
A Detailer I used several times would spray something on the wheels about 60 seconds before they started with the car soap from a pressure washer. Always took every bit of the dirt, grime and whatever from every single place on the wheels. Never found out what it was. Wondering if anyone knew of something that worked this well on melting off the dirt without getting into the wheel with a brush? |
07-16-2018, 03:51 PM | #7 |
No 55mph
1622
Rep 8,476
I use the Sonax Cleaner Plus. It is the newest formulation, 30% stronger than the Full Effect and works much faster
I use it 1X/wk, removes all brake dust, dirt, any discoloration with just a garden hose - I would guess a pressure washer would be even more effective
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
IK6SPEED4490.00 |
07-16-2018, 06:08 PM | #9 | |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Plus definitely works better than Full Effect or Car Guys' wheel cleaner though. I like the spray nozzle on it. It's much better at getting a wider area with even spray. A bottle doesn't last very long though... |
IK6SPEED4490.00 |
07-16-2018, 06:15 PM | #10 |
Rep 1,055
Iron X is quite good as a cleaner for the wheels, but I still use a degreaser (SuperClean) in a 3:1 with distilled water to take the browning out of my tires. And you gotta scrub for the tires.
I'm curious if there's a 1 spray fits all as well but to remove/stop corrosion from industrial runoff and pull the browning from the tires is a tall order. |
IK6SPEED4490.00 |
07-16-2018, 07:06 PM | #11 | |
Rep 10,473
Ugh. |
07-19-2018, 10:30 AM | #12 |
National Championship #17 and Counting!
793
Rep 1,508
I use P21S Gel cleaner for wheels and tires; buy it by the gallon and it lasts all year. I wait for 25% sales on Autogeek.net which happens at least once per quarter.
Sonar Plus does work great. I would not use Iron X for regular wheel cleaning, as it is a waste, costly, and smells terrible as someone pointed out. I use Iron X before twice annual paint corrections. I've never found a cleaner where I didn't need to follow up with a cheap microfiber towel. Just be sure that whatever you use is PH neutral, which means stay away from crap at Autozone unless you find Griots at Advance Auto.
2018 i3s - Melbourne Red, Tera World, Ceramic Film all windows
Packs: Technology, Driver Assistance, HK Audio, Park Distance Control |
IK6SPEED4490.00 |
07-19-2018, 10:50 AM | #13 |
Rep 10,473
07-19-2018, 12:39 PM | #14 |
Rep 1,055
07-20-2018, 01:46 PM | #15 |
Rep 1,101
Did the wheel dirt/grime turn RED and run off? If it did then it is something like SONAX or similar. If it didn't then they may have used a strong degreaser. I have a buddy that uses a strong degreaser on his wheels and it certainly takes everything off however I have read he label and it is some bad strong stuff! I read the warnings and I wouldn't use it on my wheels. However, he uses it on his wheels (Porsche Cayman) and figures since he rinses it off quickly he won't have problems. His car is 6-7 years old and his wheels haven't had any issues but it still doesn't make me want to switch to that stuff.
07-20-2018, 02:16 PM | #17 | |
Rep 10,473
What is the stronger stuff called? |
07-20-2018, 02:20 PM | #18 |
Rep 10,473
07-20-2018, 03:20 PM | #19 |
Rep 1,912
I never let my wheels get black/heavy brake dust, but I can say medium dirty wheels left for a week odd come up clean & I mean no need to touch the wheel with anything.
Happy Motoring
Evdok |
07-20-2018, 03:28 PM | #20 |
¯\_(ツ)_/¯
537
Rep 1,000
Do you know what color the liquid was? Honestly it's probably a diluted solution of Dawn, bc it's cheaper than them buying wheel cleaner
i've used this and it works pretty well https://www.amazon.com/Best-Wheel-Ti.../dp/B014V9GFJU |
07-20-2018, 07:18 PM | #21 |
Rep 6,696
Drives: F30 340i
there is no such thing as a 100% hands free wheel cleaner.
either your wheels were relatively clean to begin with and the detailer just spray wheel cleaner on to get some light dirt off or you might have not watched his whole process. i'm not trying to rain on your parade i'm just saying ask any detailer and they will agree there is no such thing as a true no agitating wheel cleaner on the market. |
07-20-2018, 07:21 PM | #22 | |
Rep 10,473
