06-19-2008, 09:08 AM | #1 |
Rep 8
hi guys..Question again
HI GUYS
This saturday i will going to the track with my M3.. Just want ask you guys on the track if i turn the MDM how it feel?? really dangerous? or not really and how about i push the fuel..i cant push it street away right? What about i turn the DSC OFF...how i gonna control it.......... i konw the race track because i was went there with my GTR34 befor .but this time is rear wheel drive..what about the lines??big different to the 4WD?? Thanks guys |
06-19-2008, 09:18 AM | #2 |
Rep 532
I would get a feel for the car in MDM mode. You should be fine, as long as you use common sense and realize that it won't save you if you barrel into a corner at 100mph and rely on the car to save you. As you gradually apply power through a corner, MDM will let you "get out" a little bit but you can correct yourself prior to it totally neutering you.
06-19-2008, 09:19 AM | #3 |
Rep 46,029
there's a thread by DJ9 i believe... let me search for it
here: http://www.m3post.com/forums/showthread.php?t=145346 http://www.m3post.com/forums/showthread.php?t=146609 good luck, please do share ur experience |
06-19-2008, 10:04 AM | #6 |
Rep 8,033
Use MDM if this is the first time you are tracking this car. And take it to a wet skidpad or an empty parking lot in the rain to explore the traction limits and kick the tail out several times. If you get on the gas too fast out of a tight corner without MDM, you can lose it. MDM does not kick-in at the track as often as one would expect. You will certainly have fun with it.
06-19-2008, 10:05 AM | #7 |
Rep 8
dont make me afride man...:)
06-19-2008, 10:51 AM | #8 |
Rep 7,887
Use the MDM till you get used to the car & track.If you find it intervening quite a bit and you are feeling comfortable then you could turn it off totaly(no traction control).I run with it off 100% of the time on track and this car will not do anything diabolical without giving you lots of warning.The M3 is a very forgiving car on track and is a lot of fun.Just go have a good time and build your speed up slowly and you will enjoy it.
06-19-2008, 10:57 AM | #10 | |
Rep 7,887
06-19-2008, 11:16 AM | #11 | |
Rep 8,033
06-19-2008, 11:37 AM | #12 |
Rep 7,887
It was also a track that was mostly 2nd & 3rd gear so sliding the car around a lot is very easy to do.I suspect that on a faster track like big Mosport,MDM on would be a lot less intrusive.The MDM is a welcome safety net for those that wish to use it.
06-26-2008, 01:28 AM | #13 | |
Rep 657
I do think MDM will save your ass, but as some have stated, it still does shave speed off the car; especially when getting on the gas post turn in....it was kicking in still more than i would have preferred...but i still did appreciated it more than not; and did not have the balls just yet to go full DSC off. I also have a sneaking suspicion that DSC in MDM tends to kick in at times in a contradicting fashion. What i mean by that is, MDM will let you throw the back out and break the rear lose to a point and under certain circumstances. However, I did encounter times when I was coming in very hot to a turn, would brake very late, or even trail brake(lol) while turning, and then gas hard during/post apex....DSC would come on......despite the back not sliding out, simply just changing dynamics quickly. I think this is attributed to the calculation settings of the DSC programming taking into account speed, braking, steering, etc etc, all at the same time.....the car probably thought i was trying to avoid an accident and starting cutting power Anyhow, food for thought!
-Dave
2008 E92M3-Space Gray Eisenmann Sport Exhaust_MT/Loaded Last edited by DJ9; 06-26-2008 at 01:45 AM.. |
